MHB What is the Solution to Part B in Newton's Law of Cooling Problem?
cbarker1
MHB
Dear Everyone,
I need some help figuring part b in this problem.
In the book states, "According to Newton's Law of Cooling, if an object at temperature T is immersed in a medium having a constant temperature M, then the rate of change of T is proportional to the difference of temperature M-T. This gives the differential equation $\frac{dT}{dt}=k(M-T)$."
a) Solve the differential equations
b) A thermometer reading $100^{\circ}$F is placed in a medium having a constant temperature of $70^{\circ}$F. After 6 mins, the thermometer reads $80^{\circ}$F. What is the reading after 20 mins?
The Work for part a:
$\frac{dT}{M-T}=k dt$
$\int{\frac{dT}{M-T}}=\int{kdt}$
Let $u=M-T$
$du=-dT$
$\int\frac{du}{u}=-k\int{dt}$
$\ln\left({\left| u \right|}\right)=-kt+C$
$e^{\ln\left({\left| u \right|}\right)}=e^{-kt+C}$
$\left|u \right|=e^{-kt}*e^{C}$
$u=\pm Ae^{-kt}$
$M-T=Be^{-kt}$
$T(t)=M-Be^{-kt}$
part b:
T(0)=100
T(6)=80
T(20)= ?
M=70 ?
I have trouble figuring out k and M.
Thanks for your help
Carter
I would choose to express the solution as:
$$T(t)=\left(T_0-M\right)e^{-kt}+M$$
where $T_0=100,\,M=70$ thus:
$$T(t)=\left(100-70\right)e^{-kt}+70=30e^{-kt}+70=10\left(3e^{-kt}+7\right)$$
Now we need to find the heat transfer coefficient $k$. We are told:
$$T(6)=80$$
Thus:
$$10\left(3e^{-6k}+7\right)=80$$
Can you proceed to solve for $k$?
$k-\frac{1}{6}\ln\left({\frac{1}{3}}\right)=\frac{1}{6}\ln\left({3}\right)$
I got the final answer right.
Thanks for the help.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
