What is the solution to Problem of the Week #172?
  • MHB
  • Thread starter Ackbach
  • Tags
    2015
In summary, the conversation centered around the topic of climate change and its impact on the environment. The participants discussed the effects of human activity on the planet and the urgent need for action to mitigate these effects. They also talked about potential solutions and ways to raise awareness about the issue. Overall, the conversation highlighted the importance of addressing climate change and the role that individuals and communities can play in making a positive impact."
Ackbach
MHB
4,155
92
Here is this week's POTW:
A number of different objects has been distributed into $n$ boxes $B_{1}, B_{2}, \dots ,B_{n}.$ All the objects from these boxes are removed and redistributed into $n+1$ new boxes $B_{1}^{*}, B_{2}^{*}, \dots , B_{n+1}^{*},$ with no new box empty (so the total number of objects must be at least $n+1$). Prove that there are two objects each of which has the property that it is in a new box that contains fewer objects than the old box that contained it.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
No one solved this week's POTW. Here is a solution I found online:
Represent the situation as a bipartite graph where one color class are the $B_{i}$'s; the others are the $B^*_{j}$'s - hereafter referred to as the $A_{j}$'s. We can do this by letting each edge connecting $B_{i}$ to $A_{j}$ represent an object that is moved from $B_{i}$ to $A_{j}$.
Now fix $n$ and induct on the total number of edges $k$. Note $k >= n + 1$. Induct on $k$.
Base: If $k=n+1$, exactly one of the $B_{i}$'s has degree two; the rest have degree $1$. Said $B_{i}$ must be adjacent to an $A_{m}$ and an $A_{j}$ each with degree one. Those edges are the objects you want.
Induction: Suppose it holds for $k - 1$ and look at a situation with $k$ edges. Now if the graph is such that there exists two adjacent vertices each with degree $> 1$, remove the edge connecting them. The new graph satisfies the situation of the problem and the induction hypothesis. If not, then it must be that every edge touches a vertex with degree $1$. Say there are $a$ degree one $B$'s adjacent to degree one $A$'s, $b$ degree one $B$'s adjacent to non-degree one $A$'s, and $c$ non-degree one $B$'s adjacent to degree one $A$'s. Then $n = a + b + c$. If $c > 0$ we are done, as we can pick one of the $B$'s of this class and two of the edges connected to that $B$. If $c = 0$ then the total number of $B$'s is $n = a + b$ and the total number of edges is $k = a + b$. Since $k >= n + 1$ this is impossible. So $c > 0$ and we're done.
FAQ: What is the solution to Problem of the Week #172?
What is the Problem of the Week #172?
The Problem of the Week #172 is a mathematical puzzle that is posted weekly on a website or platform for people to solve and submit their solutions.
What is the purpose of Problem of the Week #172?
The purpose of Problem of the Week #172 is to challenge individuals to think critically and creatively in order to solve a complex problem. It also helps to improve problem-solving skills and logical reasoning abilities.
How is the solution to Problem of the Week #172 determined?
The solution to Problem of the Week #172 is determined by a set of rules or criteria set by the organizer. These rules may include specific steps or calculations that need to be followed in order to arrive at the correct solution.
Is there only one correct solution to Problem of the Week #172?
Typically, there is only one correct solution to Problem of the Week #172. However, depending on the complexity of the problem, there may be multiple approaches or methods to arrive at the correct solution.
What happens if I cannot solve Problem of the Week #172?
If you are unable to solve Problem of the Week #172, you can still submit your attempt or solution to the organizer. Some platforms may also provide hints or explanations for the problem after the submission deadline has passed.
