What is the solution to r^(n+1)*(1-r) in calculus?
  • Thread starter Roscoe1989
  • Tags
    Calculus
In summary, the conversation revolves around solving a proof with the equation r^(n+1)*(1-r)=1+r+...+r^n=1-r^(n+1)/1-r, with some confusion about the base case and the use of induction. The base case is when n = 0 and the inductive step involves showing that the equation holds for n+1, which is 1+r+...+r^(n+1)=1-r^(n+1+1)/(1-r). Ultimately, the conversation ends with a better understanding of the concept of induction and how it applies to the given equation.
  • #36
ok...so when the right side equals the left side... what does that mean?
  • #37
flyingpig said:
Yeah I probably wouldn't do that [induction] either. But Ros asked for
in post 3
Ok, missed the "induction" bit in there.
  • #38
fluidistic said:
Dick and flyingpig, you are missing, I think, that roscoe1989 doesn't know what happens in the LHS when n=0.
When n=0, you don't get 1+r²+r³+...+r⁰.
1+r²+r³+...+r^n is just a notation. When n=0 you simply get r⁰ and this is worth 1. So when n=0, both the LHS and RHS is worth 1, so the equality holds, meaning that it does makes sense to consider n=0 (it's a possible/allowed value for n).
Yeah and I am trying to lead Ros to that.
  • #39
ooooooh, ok
  • #40
That means the equal sign worked!
flyingpig said:
It's probably that I tell you what Induction is (in brief form) first.
(1) Base Case. Usually we take n = 1 or 0. We show that it (S(n)) is true first
(2) Inductive Step. Assume that (1) is true and then you will write your Inductive hypothesis and show that it is true for S(n+1).
  • #41
Roscoe1989 said:
ooooooh, ok
I just led to the base case, so we just did (1).
  • #42
so then to prove (2), we would have to do n+1, which, in our case, is 0+1=1 and that would give us 1-r^2 / 1-r right?
  • #43
Where did you get the 0 from...? I have to go to sleep soon...
  • #44
sorry, i meant 1+1=2. you've been really helpful, and don't let me keep you awake! :)
  • #45
I have to leave now because by the time I get back, I would be very late already. I will leave you with this.
When I said "n + 1" , I mean for a general n. The base case is when we take the most fundamental n. It just happened to be 0.
So you have to show this
[tex]1 + r + r^2 +...+r^{n+1} = \frac{1 - r^{n + 1 + 1}}{1 - r}[/tex]
  • #46
thanks flyingpig, you've been a great help!
