What is the Solution to the Differentiation Problem for a Descending Plane?
In summary, a plane begins its descent at time t = 0 and position s = 0, with a distance s in km as a function of time t in hours given by s = 300 + 400t - 200t^3. The initial velocity is calculated to be 300 km/hr and the acceleration after 1/2 hr is 475 km/hr2. The question asks for the time when the velocity is zero and the distance traveled in that time. To solve this, we set the equation for velocity equal to zero, resulting in 0 = 400 - 600t^2. There were difficulties with transposing this equation for t, but it was determined that the equation is correct for velocity.
At time t = 0 and position s = 0 a plane starts its descent into an airfield. From this point, the distance s in km as a function of time t in hours is given by;
The inital velocity I have calculated to be 300 km/hr and the acceleration after 1/2 hr is 475 km/hr2. I am having problems with the last question;
c) the time to when the velocity is zero and the distance traveled in that time?
So, what's the equation for velocity? Set it equal to zero and solve for t.
I did this and came out with 0 = 400 - 600t^2
I had difficulty transposing this for t as I kept getting discrepencies. Once I have t I can do the rest, I am not even sure if the above equation is correct for velocity.
What do you mean?
It is.
I came out with t = -400/600^2 but I wasnt confident with the number this came out to.
Check your algebra. The solution of 0 = 400 - 600t2 is not t = - 400/6002.
FAQ: What is the Solution to the Differentiation Problem for a Descending Plane?
What is a differentiation problem?
A differentiation problem is a mathematical problem that involves finding the rate of change of a function at a particular point. It is a fundamental concept in calculus and is used to solve various real-world problems, such as finding velocity, acceleration, and optimization.
What is the process of differentiation?
The process of differentiation involves finding the derivative of a function. This is done by applying various rules and formulas, such as the power rule, product rule, and chain rule, to the function. The result of differentiation is a new function that represents the rate of change of the original function.
Why is differentiation important?
Differentiation is important because it allows us to understand the behavior of functions and how they change over time or space. It is used in many fields, including physics, economics, and engineering, to solve problems and make predictions. It is also a crucial concept for higher-level mathematics, such as multivariable calculus and differential equations.
What are some common applications of differentiation?
Some common applications of differentiation include finding the maximum and minimum values of a function, determining the slope of a curve, and calculating the rate of change of a quantity over time. It is also used in optimization problems, where we want to find the best solution given certain constraints.
How can I improve my understanding of differentiation?
To improve your understanding of differentiation, it is important to practice solving different types of problems and familiarize yourself with the various rules and formulas. You can also seek help from a tutor or online resources, such as tutorials and practice exercises. It is also helpful to make connections between differentiation and real-world applications to better understand its relevance.
