MHB What is the solution to this hard system of equations?
The discussion revolves around solving a challenging system of equations involving variables a, b, and c. The user expresses frustration over multiple failed attempts to find a solution, including multiplying equations and rewriting them, but has not made significant progress. Another participant suggests a method involving differences of the equations, which leads to further equations, but the user remains confused and unable to reach a conclusion. The conversation highlights the complexity of the problem and the collaborative effort to find a solution, with no clear resolution yet. The thread illustrates the difficulties faced in solving non-linear systems of equations.
anemone
MHB
POTW Director
Hi MHB,
This problem has been one big headache for me and I failed miserably every time that I attempted it. I thought to dump it into the trash, but I couldn't, simply because I would like very much to solve it.
So, I hope to get some good help from this site and I thank anyone who wants to help me out with this problem in advance.
Problem:
Solve the system in real numbers:
$\dfrac{1}{ab}+\dfrac{1}{b}+\dfrac{1}{c}=\dfrac{5}{11}$
$\dfrac{1}{bc}+\dfrac{1}{c}+\dfrac{1}{a}=\dfrac{3}{8}$
$\dfrac{1}{ac}+\dfrac{1}{a}+\dfrac{1}{b}=\dfrac{9}{11}$
Attempt:
Multiplying all of the three equations by $abc$ and then addding them up yields
$a+b+c+2(ab+bc+ca)=\dfrac{145abc}{88}$ which, I don't think, it helps much.
Attempt 2:
By rewriting the equations such that we would end up with an equation in terms of one variable, e.g. $a$ doesn't help much either...
I would show only the end result here:
$121(a^2-1-1)^2+(11()88)a(9a-16)(a^2-1-1)+88a^2(9a-16)^2=a(9a-16)(64+57a-136a^2)$
Mathematics news on Phys.org
anemone said:
Hi MHB,
Problem:
Attempt:
Attempt 2:
in
you can put
$\dfrac{1}{ab}=\dfrac{1-b}{ab}+\dfrac{1}{a}$
to get
$\dfrac{1-b}{ab}+\dfrac{1}{a}+\dfrac{1}{b}+\dfrac{1}{c}=\dfrac{5}{11}$
similarly other 2 equations and take differences and then result should follow
kaliprasad said:
...d take differences and then result should follow
Thanks for the reply, kaliprasad!:)
Okay, here is what I did following your hint, but I just couldn't see the way to finish it, am I missing something obvious here?(Tmi)
$\dfrac{1-b}{ab}+\dfrac{1}{a}+\dfrac{1}{b}+\dfrac{1}{c}=\dfrac{5}{11}$---(1)
$\dfrac{1-c}{bc}+\dfrac{1}{a}+\dfrac{1}{b}+\dfrac{1}{c}=\dfrac{3}{8}$---(2)
$\dfrac{1-a}{ac}+\dfrac{1}{a}+\dfrac{1}{b}+\dfrac{1}{c}=\dfrac{9}{11}$---(3)
[TABLE="width: 700"]
[TR]
[TD](1)-(2) gives
$\dfrac{1-b}{ab}-\dfrac{1-c}{bc}=\dfrac{7}{88}$[/TD]
[TD](3)-(1) gives
$\dfrac{1-a}{ac}-\dfrac{1-b}{ab}=\dfrac{4}{11}$[/TD]
[/TR]
[/TABLE]
Sorry kaliprasad...I don't think the result of their difference or sum help here...:(
$\left(\dfrac{1-b}{ab}-\dfrac{1-c}{bc}\right)-\left(\dfrac{1-a}{ac}-\dfrac{1-b}{ab}\right)=\dfrac{7}{88}-\dfrac{4}{11}\implies\,\,\,2\left(\dfrac{1-b}{ab}\right)-\left(\dfrac{a+b-ac-ab}{abc}\right)=-\dfrac{25}{88}$
or
$\dfrac{1-a}{ac}-\dfrac{1-c}{bc}=\dfrac{39}{88}$
But, if I were to do it like the following, then I ended up with something different, I don't know, I am completely lost in this problem:
$\dfrac{1-b}{ab}-\dfrac{1-c}{bc}=\dfrac{7}{88}=\dfrac{7}{32}\cdot\dfrac{4}{11}=\dfrac{7}{32}\left(\dfrac{1-a}{ac}-\dfrac{1-b}{ab}\right)$
Simplifying gives
$39c-32a-7b=39bc-32ac-7ab$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
