What is the solution to this week's challenging integral problem?
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, an integral problem is a type of mathematical problem that involves finding the area under a curve or the accumulation of a certain quantity. To approach a challenging integral problem, one should identify the type of integral, function, and limits/variables, and use appropriate techniques like substitution, integration by parts, or partial fractions. To determine the correctness of a solution, one can take the derivative of the integrated function and check if it matches the original function. Integral problems can have multiple solutions, but they should all yield the same result when evaluated within the given limits/variables.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Compute \(\displaystyle \int_{0}^{\pi} \dfrac{2\sin x+3\cos x-3}{13\cos x-5} \,dx\).
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. Opalg
2. greg1313
Solution from Opalg:
At first sight, this looks like an improper integral, because the denominator vanishes when $\cos x = \frac5{13}$. But if $\cos x = \frac5{13}$ then (from the 5-12-13 pythagorean triple) $\sin x = \frac{12}{13},$ which means that $2\sin x + 3\cos x -3 = 0.$ So the numerator also vanishes at that point, and in fact there is no singularity.
To evaluate the integral, use the magical substitution $t = \tan\frac x2$. Then $\sin x = \frac{2t}{1+t^2}$, $\cos x = \frac{1-t^2}{1+t^2}$ and $dx = \frac2{1+t^2}\,dt$. So $$\frac{2\sin x + 3\cos x -3}{13\cos x - 5} = \frac{4t + 3(1-t^2) - 3(1+t^2)}{13(1-t^2) - 5(1+t^2)} = \frac{4t - 6t^2}{8-18t^2} = \frac{2t(2-3t)}{2(2-3t)(2+3t)} = \frac{t}{2+3t},$$ and the integral becomes $$\int_0^\pi \frac{2\sin x + 3\cos x -3}{13\cos x - 5}\,dx = \int_0^\infty\frac t{2+3t}\frac2{1+t^2}\,dt.$$ Next, use partial fractions to get $$\frac{2t}{(2+3t)(1+t^2)} = -\frac{12}{13}\frac1{2+3t} + \frac4{13}\frac t{1+t^2} + \frac6{13}\frac 1{1+t^2}.$$ That function has an indefinite integral $$f(t) = -\frac4{13}\ln(2+3t) + \frac2{13}\ln(1+t^2) + \frac6{13}\arctan t = \frac2{13}\ln\Bigl(\frac{1+t^2}{(2+3t)^2}\Bigr) + \frac6{13}\arctan t.$$
At the lower end of the interval of integration, \(\displaystyle f(0) = -\frac4{13}\ln2\). At the upper end, \(\displaystyle \lim_{t\to\infty}\frac{1+t^2}{(2+3t)^2} = \frac19,\) and so \(\displaystyle \lim_{t\to\infty}f(t) = \frac2{13}\ln\Bigl(\frac19\Bigr) + \frac6{13}\frac\pi2 = -\frac4{13}\ln3 +\frac{3\pi}{13}.\)
In conclusion, \(\displaystyle \int_0^\pi \frac{2\sin x + 3\cos x -3}{13\cos x - 5}\,dx = -\frac4{13}\ln3 +\frac{3\pi}{13} + \frac4{13}\ln2 = \frac{3\pi - 4\ln(3/2)}{13}.\)
FAQ: What is the solution to this week's challenging integral problem?
What is an integral problem?
An integral problem is a type of mathematical problem in which the goal is to find the area under a curve or the accumulation of a certain quantity. It involves finding the anti-derivative of a given function and evaluating it within a given range.
How do you approach a challenging integral problem?
The best approach to solving a challenging integral problem is to start by identifying the type of integral (definite or indefinite), the type of function (polynomial, trigonometric, exponential, etc.), and the given limits or variables. Then, use the appropriate integration techniques such as substitution, integration by parts, or partial fractions to solve the problem step by step.
What are some common integration techniques?
Some common integration techniques include substitution, integration by parts, partial fractions, and trigonometric substitution. These techniques are used to simplify the integrand and make it easier to integrate.
How do you know if your solution to an integral problem is correct?
You can check the correctness of your solution by taking the derivative of the function you obtained through integration. If the derivative matches the original function given in the problem, then your solution is correct.
Can integral problems have multiple solutions?
Yes, integral problems can have multiple solutions. This is because there can be different ways to approach and simplify the integrand, leading to different anti-derivatives. However, the solutions should all yield the same result when evaluated within the given limits or variables.
