What is the stability analysis for a discrete model with r > 0?
In summary, the conversation discusses the steady states of a function and their stability. Two steady states are identified, $N_* = 0$ and $N_* = \frac{\sqrt[b]{r} - 1}{a}$, and their corresponding stability is analyzed. The stability of $N_* = 0$ changes at $r = 1$, while the stability of $N_* = \frac{\sqrt[b]{r} - 1}{a}$ changes at $r = \frac{a}{\frac{b}{\sqrt[b]{a}} - b + 1}$, with the possibility of both a tangent and pitchfork bifurcation. This analysis is valid for all values of $a$
Dustinsfl
2,281
I am dealing with (below) and r > 0
N_{*} = \frac{rN_*}{(1 + aN_*)^b}
So the steady states are $N_* = 0$ and $N_* = \frac{\sqrt{r} - 1}{a}$.
Let $f(x) = \frac{rx}{(1 + ax)^b}$.
Then $f'(x) = (ax + 1)^{-b}\left(\frac{br}{ax + 1} + (1 - b)r\right)$.
Evaluating the derivative at $N_*$, we obtain
f'(0) = r \quad \text{and} \quad
f'\left(\frac{\sqrt{r} - 1}{a}\right) = \frac{r}{a}\left(\frac{b}{\sqrt{a}} - b + 1\right).
For $N_* = 0$, $0 < f'(0) < 1$ for $0 < r < 1$.
For this range of $r$, $N_* = 0$ is stable monotonically.
For $r > 1$, $f'(0) > 1$ which is unstable monotonically, and at $r = 1$, we have a tangent bifurcation.
Now when I examine $N_* = \frac{\sqrt{r} - 1}{a}$, I need to find when $f'(N_*) = 1$ for the tangent bifurcation and when $f'(N_*) = -1$ for the pitchfork.
However, I have this if the f'(N_*) = 1
r = \frac{a}{\frac{b}{\sqrt{a}}-b+1}
So would this be the correct way to do this or does it need to be done be considering a and b?
For $N_* = \frac{\sqrt{r} - 1}{a}$, $0 < f'\left(\frac{\sqrt{r} - 1}{a}\right) < 1$ for $0 < r < \frac{a}{\frac{b}{\sqrt{a}} - b + 1}$ which is stable monotonically.
If $r > \frac{a}{\frac{b}{\sqrt{a}} - b + 1}$, then $f'\left(\frac{\sqrt{r} - 1}{a}\right) > 1$ which is unstable monotonically, and at $r = \frac{a}{\frac{b}{\sqrt{a}} - b + 1}$, we have a tangent bifurcation.
For $\frac{-a}{\frac{b}{\sqrt{a}} - b + 1} < r < 0$, $-1 < f'\left(\frac{\sqrt{r} - 1}{a}\right) < 0$ so we have a stable oscillations.
When $r < \frac{-a}{\frac{b}{\sqrt{a}} - b + 1}$, there are unstable oscillations, and at $r = \frac{-a}{\frac{b}{\sqrt{a}} - b + 1}$, we have a pitchfork bifurcation.
I could I say this to contend for a and b:
This stability analysis is valid for all $a,b$ such that $r > 0$.
Mathematics news on Phys.org
For $N_* = 0$, $f'(0)$ is monotonically increasing with respect to $r$ and the stability changes at $r = 1$.
For $N_* = \frac{\sqrt{r} - 1}{a}$, $f'\left(\frac{\sqrt{r} - 1}{a}\right)$ is monotonically increasing with respect to $r$ and the stability changes at $r = \frac{a}{\frac{b}{\sqrt{a}} - b + 1}$.
For $\frac{-a}{\frac{b}{\sqrt{a}} - b + 1} < r < 0$, $f'\left(\frac{\sqrt{r} - 1}{a}\right)$ has stable oscillations and the stability changes at $r = \frac{-a}{\frac{b}{\sqrt{a}} - b + 1}$ with an accompanying pitchfork bifurcation.
FAQ: What is the stability analysis for a discrete model with r > 0?
What is a discrete model analysis?
A discrete model analysis is a statistical method used to analyze data that is collected in discrete or distinct categories. It involves the use of mathematical models to understand and interpret patterns and relationships within the data.
What are the advantages of using discrete model analysis?
Discrete model analysis allows for the identification of patterns and trends within categorical data. It also allows for the testing of hypotheses and the prediction of outcomes based on the data.
What are some common applications of discrete model analysis?
Discrete model analysis is often used in fields such as epidemiology, genetics, and market research. It can be applied to a wide range of data sets that involve categorical variables, such as survey responses, disease diagnoses, and product sales.
What are the limitations of discrete model analysis?
Discrete model analysis assumes that the data is independent and identically distributed, which may not always be the case in real-world scenarios. Additionally, the results of discrete model analysis may be influenced by the choice of model and assumptions made during the analysis.
How can I learn more about discrete model analysis?
There are many resources available to learn more about discrete model analysis, including online tutorials, textbooks, and workshops. It is also helpful to have a strong understanding of statistics and mathematical modeling in order to effectively apply and interpret the results of discrete model analysis.
10K
