What is the standard enthelpy of formation of NaF
In summary, the standard enthalpy of formation of NaF is a measure of the energy released or absorbed when one mole of NaF is formed from its constituent elements at standard conditions. It is determined experimentally using a calorimeter and can indicate the stability of a compound. Factors such as temperature, pressure, and physical state can affect its value. The standard enthalpy of formation is also related to other thermodynamic properties and can be used to calculate the feasibility of a chemical reaction.
deuce1906
Please help! i just need to see one step by step solution of how to solve this problem and then I can figure the rest out.
When .560g of Na (s) reacts with excess F2(g) to form NaF(s), 13.8 kj of heat is evolved at standard state conditions. What is the standard enthalpy of formation of NaF (s)?
(delta H=-569Kj/Mol)
Standard enthalpy is per mole NaF produced, you have it per 0.560g of Na. How many moles produced?
To solve this problem, we need to use the formula for standard enthalpy of formation, which is defined as the change in enthalpy when one mole of a compound is formed from its constituent elements in their standard states.
The standard state for an element is its most stable form at 1 atm pressure and a specified temperature (usually 25°C). In this case, the standard state for NaF is solid (s) at 25°C.
We are given the mass of Na (s) used in the reaction (.560g) and the amount of heat evolved (13.8 kJ). We can use the molar mass of Na (22.99 g/mol) to calculate the moles of Na used in the reaction:
moles of Na = (.560g Na) / (22.99 g/mol Na) = 0.0243 mol Na
Since the reaction is at standard state conditions, we can use the definition of standard enthalpy of formation to set up an equation:
(delta Hf) = (heat evolved) / (moles of product formed)
Using the values we calculated, we can plug them in to solve for the standard enthalpy of formation of NaF:
(delta Hf) = (13.8 kJ) / (0.0243 mol) = -569 kJ/mol
Therefore, the standard enthalpy of formation of NaF is -569 kJ/mol.
Related to What is the standard enthelpy of formation of NaF
1. What is the standard enthalpy of formation of NaF?
The standard enthalpy of formation of NaF is the amount of energy released or absorbed when one mole of NaF is formed from its constituent elements under standard conditions of 25°C and 1 atmosphere pressure.
2. How is the standard enthalpy of formation of NaF determined?
The standard enthalpy of formation of NaF is determined experimentally by measuring the heat released or absorbed during the formation of NaF from its constituent elements, using a calorimeter.
3. What is the significance of the standard enthalpy of formation of NaF?
The standard enthalpy of formation of NaF is a useful measure of the stability of a compound. A more negative value indicates a more stable compound, while a positive value indicates a less stable compound.
4. What factors can affect the standard enthalpy of formation of NaF?
The standard enthalpy of formation of NaF can be affected by temperature, pressure, and the physical state of the reactants and products. Changes in these factors can lead to variations in the enthalpy of formation.
5. How does the standard enthalpy of formation of NaF relate to other thermodynamic properties?
The standard enthalpy of formation of NaF is related to other thermodynamic properties such as the standard enthalpy of reaction and the standard free energy change. It can be used to calculate these properties and determine the feasibility of a chemical reaction.
