What is the Sum of Digits in the Power of Three Raised to 10,000?
  • MHB
  • Thread starter Albert1
  • Tags
    Sum
In summary, the solution for finding C when given X=3^{10000}, $log_{10} 3=0.4771$, and the sum of digits of X is A, the sum of digits of A is B, and the sum of digits of B is C, is as follows: A is less than 4772*9 or 50000, B is less than 41, and C is less than or equal to 12. The range for A, B, and C is correct, with A being a 5-digit number, B being a 2-digit number, and C being less than 18.
Albert1
1,221
$ X=3^{10000}$
Given $log_{10} 3=0.4771$
All the digits sum of X =A
All the digits sum of A =B
All the digits sum of B =C
please find C
Mathematics news on Phys.org
Albert said:
$ X=3^{10000}$
please find C
this is 4771 digits so A < 4771 * 9 or A < 50000
B < 41 so C <= 12 ( if b were 39)
X mod 9 = C mod 9
ax x mod 9 = 0 so C= 0 or 9 as it cannot be 18
as C cannot be zero it is 9
X mod 9 = C mod 9
the answer is correct ,but X is not 4771 digits
Thanks
it is my mistake x is 4772 digits
B < 41 so C <= 12
here the range of A,B,and C should be edited
(the range of A,B,and C are not correct)
B < 41 so C <= 12
so I replace it with correct solution
A < 4772 * 9 or < 47720 or < 50000
I have taken for A to be the worst case. hence A and B range is OK
A is 5 digits number
$B<5\times 9=45$
B is 2 digits number
$C<2\times 9=18$
I think your range is OK (more rigid )
FAQ: What is the Sum of Digits in the Power of Three Raised to 10,000?
What does "Find the sum of all digits" mean?
"Find the sum of all digits" refers to the process of adding together all of the digits in a given number to find the total sum.
How do I find the sum of all digits in a number?
To find the sum of all digits in a number, you must first separate each digit and then add them together. For example, if the number is 123, you would add 1 + 2 + 3 to get a sum of 6.
Can the sum of all digits be negative?
No, the sum of all digits will always be a positive number. This is because the digits in a number are always positive and adding them together will result in a positive number.
What if the number has a decimal point?
If the number has a decimal point, you can either round the number to the nearest whole number and then find the sum of all digits, or you can include the digits after the decimal point in the sum.
Why is finding the sum of all digits important?
Finding the sum of all digits can be useful in various mathematical calculations and can help in understanding the properties and patterns of numbers. It can also be used to check the accuracy of calculations or to solve certain mathematical problems.
