What is the Sum of Roots for $P(x)=x^3-2x^2-x+1$ with $x_1>x_2>x_3$?
  • MHB
  • Thread starter anemone
  • Tags
    Roots Sum
In summary, the conversation involved discussing the real roots of a polynomial and evaluating an expression involving those roots. A subtle hint and a follow-up hint were given, and the participants thanked each other for their contributions. The speaker also apologized for being late and expressed their sickness.
anemone
MHB
POTW Director
3,883
115
Let $x_1,\,x_2,\,x_3$ be the three real roots of $P(x)=x^3-2x^2-x+1$ such that $x_1>x_2>x_3$.
Evaluate $x_1^2x_2+x_2^2x_3+x_3^2x_1$.
Mathematics news on Phys.org
Subtle hint:
Make full use of the expressions $x_1^2x_2+x_2^2x_3+x_3^2x_1$ and $x_1x_2^2+x_2x_3^2+x_3x_1^2$.
anemone said:
Subtle hint:
Follow-up hint:
Relate $x_1^2x_2+x_2^2x_3+x_3^2x_1$ and $x_1x_2^2+x_2x_3^2+x_3x_1^2$ with
1. $x_1+x_2+x_3$,
2. $x_1x_2+x_2x_3+x_3x_1$,
3. $x_1x_2x_3$.
anemone said:
Follow-up hint:
1. $x_1+x_2+x_3$,
3. $x_1x_2x_3$.
I've managed to get as far as
$x_1^2x_2+x_2^2x_3+x_3^2x_1+x_1x_2^2+x_2x_3^2+x_3x_1^2=1$
Currently, I don't see a way of progressing any further.
Let $S_1=x_1^2x_2+x_2^2x_3+x_3^2x_1$
and $S_2 = x_1x_2^2 + x_2x_3^2 + x_3x_1^2$
(slight cheat here used a computer)
We have $P(-.9)=-.449,P(-.8)=.008,P(.5)= .125,P(.6)=-.104, P(2.2)=-.232, P(2.3) = .287$
It follows that the roots satisfy $-.9<x_3<-.8, .5<x_2<.6$ and $2.2<x_1<2.3$
This implies that $x_1^2x_2 + x_2^2x_3+ x_3^2x_1 > 0$
or $S_1 > 0$
Now $S_1 + S_2 = (x_1^2x_2+x_2^2x_3+x_3^2x_1) + (x_1x_2^2 + x_2x_3^2 + x_3x_1^2)$
$= x_1x_2(x_1+x_2) + x_2x_3(x_3+x_2)+ x_3x_1(x_3+x_1)$
$= (x_2+x_3+x_1)(x_1x_2+x_2x_3+ x_3x_1) - 3 x_1x_2x_3$
$= 2 * (-1) + 3 = 1$
The product $S_1S_2$ is
$S_1S_2 = (x_1^2x_2 + x_2^2x_3 + x_3^2x_1^2)(x_1x_2^2 + x_2x_3^2 + x_3x_1^2)$
= $x_1^3x_2^3 + x_2^3x_3^3 + x_3^3x_1^3 + 3x_1^2x_2^2 x_3^2 + x_1x_2x_3(x_1^3 + x_2^3 + x_3^3)$
Now we need to evaluate $x_1^3x_2^3 + x_2^3x_3^3 + x_3^3x_1^3$ and so on
To evaluate that, notice that the equation with roots $x_1^3,x_2^3,x_3^3$ by
letting $y = x^3 $in the original equation, which then becomes $y+1=2(\sqrt[3]y)^2 + \sqrt[3]y$
Cube both sides to get
$y^3+3y^2+ 3y + 1 = 8y^2 + y + 6y(y+1)$
or $y^3-11y^2-4y+1=0$
Therefore $x_1^3+x_2^3+x_3^3=11$ , $x_1^3x_2^3+x_2^3x_3^3 + x_3^3x_1^3 = -4$
Substitute those values into the above displayed equation to get
$S_1S_2=-4+3-11=-12$
Thus the equation with roots $S_1$ and $S_2$ are
$x^2 -x - 12 = 0$ or $(x-4)(x+3) = 0$ so x = 4 or -3
as $S_1 > 0$ so it is 4
or $x_1^2x_2 + x_2^2x_3+ x_3^2x_1 = 4$
prove of $S_1>0$ without using a computer
$P(-1)=-1<0, P(0)=1>0, P(1)=-1<0,P(3)=7>0$
from Descartes' rule of signs
P(X) has two positive roots and one negative root
$\therefore x_1>1>x_2>0>x_3$
it is clear that:$x_1^2x_2>0,x_2^2x_3<0,$ and $x_3^2x_1>0$
this implies $S_1=x_1^2x_2+x_2^2x_3+x_3^2x_1>0$
for $x_1^2x_2>\left | x_2^2x_3 \right |$
Hi all!
I've been very busy in the past few days and I am sick today...so sorry all for the late reply!
Thanks kaliprasad for your neat and elegant solution and thanks to greg1313 and Albert as well for your participation!
Yes, greg1313, if we let $S_1=x_1^2x_2+x_2^2x_3+x_3^2x_1$ and $S_2=x_1x_2^2+x_2x_3^2+x_3x_1^2$, then $S_1+S_2=1$, but note that we could also draw some useful information if we subtract $S_2$ from $S_1$ as $S_1-S_2=(x_1-x_2)(x_2-x_3)(x_1-x_3)>0\implies S_1>S_2$ and we then see if we can write the product of $S_1$ and $S_2$ using only the expressions below:
1. $x_1+x_2+x_3$,
3. $x_1x_2x_3$.
$\begin{align*}S_1S_2&=(x_1^2x_2 + x_2^2x_3 + x_3^2x_1^2)(x_1x_2^2 + x_2x_3^2 + x_3x_1^2)\\&=x_1^3x_2^3 + x_2^3x_3^3 + x_3^3x_1^3 + 3x_1^2x_2^2 x_3^2 + x_1x_2x_3(x_1^3 + x_2^3 + x_3^3)\\&=(x_1x_2+x_2x_3+x_3x_1)^3+(x_1+x_2+x_3)^3(x_1x_2x_3)+9(x_1x_2x_3)^2-6(x_1+x_2+x_3)(x_1x_2+x_2x_3+x_3x_1)(x_1x_2x_3)\\&=-12\end{align*}$
Therefore, we get $S_1=4,\,S_2=-3$ and we're hence done! :D
anemone said:
Hi all!
wish you a speedy recovery
Thank you, Kali!
FAQ: What is the Sum of Roots for $P(x)=x^3-2x^2-x+1$ with $x_1>x_2>x_3$?
What does it mean to "evaluate the sum of roots"?
When we talk about the "roots" of a mathematical equation, we are referring to the values that make the equation true. For example, in the equation x^2 + 5x + 6 = 0, the roots are x = -2 and x = -3. To "evaluate the sum of roots" means to find the sum of these values.
How do you find the sum of roots?
To find the sum of roots, you can use the quadratic formula: x = (-b ± √(b^2 - 4ac)) / 2a. In this formula, a, b, and c represent the coefficients in the quadratic equation. Once you have found the two values of x, you can simply add them together to get the sum of the roots.
Why is it important to evaluate the sum of roots?
Evaluating the sum of roots can give us important information about the equation. For quadratic equations, the sum of roots can tell us the x-coordinate of the vertex, which is the highest or lowest point on the parabola. It can also help us determine the nature of the roots (real or complex) and whether the parabola opens upwards or downwards.
Can the sum of roots be negative?
Yes, the sum of roots can be negative. This typically occurs when the quadratic equation has two negative roots or one positive and one negative root. For example, in the equation x^2 + 2x + 1 = 0, the roots are x = -1 and x = -1, so the sum of roots is -2.
Are there any other ways to find the sum of roots?
Yes, there are other methods to find the sum of roots besides using the quadratic formula. For simpler equations, you can factor the equation and then simply add the roots. You can also use graphing techniques to estimate the sum of roots by looking at the x-intercepts of the graph. However, for more complex equations, the quadratic formula is the most reliable method to find the sum of roots.
