What is the sum of this infinite series?
In summary, the infinite series $1-\dfrac{2^3}{1!}+\dfrac{3^3}{2!}-\dfrac{4^3}{3!}+\cdots$ can be evaluated by using the identity $(n+1)^3 = n(n-1)(n-2) + 6n(n-1) + 7n + 1$ and simplifying the expression. By doing so, it is found that the series equals $-\frac1e$ due to the cancellation of terms with negative factorials in the denominators.
anemone
MHB
POTW Director
3,883
115
Evaluate the infinite series $1-\dfrac{2^3}{1!}+\dfrac{3^3}{2!}-\dfrac{4^3}{3!}+\cdots$.
Mathematics news on Phys.org
[sp]
First, you need to check the identity $(n+1)^3 = n(n-1)(n-2) + 6n(n-1) + 7n + 1.$ Then $$ \begin{aligned} \sum_{n=0}^\infty \frac{(-1)^n(n+1)^3}{n!} &= \sum_{n=0}^\infty \frac{(-1)^n \bigl(n(n-1)(n-2) + 6n(n-1) + 7n + 1\bigr)}{n!} \\ &= \sum_{n=0}^\infty (-1)^n \biggl( \frac1{(n-3)!} + 6\frac1{(n-2)!} + 7\frac1{(n-1)!} + \frac1{n!} \biggr). \end{aligned}$$ The last line there looks suspicious, because for small values of $n$ there are some factorials of negative numbers in the denominators. But if you check what happens when $n$ is small, you see that those terms can be ignored. For example, in the first term \(\displaystyle \sum_{n=0}^\infty (-1)^n \frac1{(n-3)!},\) the summation actually starts at $n=3$ rather than $n=0.$ If you replace the summation index $n$ by $n-3$ then that sum becomes \(\displaystyle \sum_{n=0}^\infty (-1)^{n+3} \frac1{n!} = -\sum_{n=0}^\infty \frac{(-1)^n}{n!}.\) Therefore $$\sum_{n=0}^\infty \frac{(-1)^n(n+1)^3}{n!} = \sum_{n=0}^\infty \biggl( -\frac{(-1)^n}{n!} + 6\frac{(-1)^n}{n!} - 7\frac{(-1)^n}{n!} + \frac{(-1)^n}{n!} \biggr) = - \sum_{n=0}^\infty\frac{(-1)^n}{n!} = -\frac1e.$$[/sp]
Very well done, Opalg and thanks for participating!:)
FAQ: What is the sum of this infinite series?
What is the sum of an infinite series?
The sum of an infinite series is the total value obtained by adding an infinite number of terms in a sequence. It is represented by the Greek letter sigma (Σ).
How do you determine the sum of an infinite series?
The sum of an infinite series can be determined by using a formula or by performing mathematical operations such as addition, subtraction, multiplication, or division on the terms of the series.
What is the difference between a finite series and an infinite series?
A finite series has a fixed number of terms, while an infinite series has an infinite number of terms. This means that the sum of a finite series will eventually reach a final value, while the sum of an infinite series may continue to increase or decrease without ever reaching a final value.
How do you know if an infinite series will converge or diverge?
An infinite series will converge if the sum of its terms approaches a finite value. It will diverge if the sum of its terms continues to increase or decrease without ever reaching a finite value.
What are some common types of infinite series?
Some common types of infinite series include geometric series, harmonic series, and Taylor series. These series have specific formulas and properties that can be used to determine their sums and convergence or divergence.
