What is the temperature at the end of the process ?
In summary, the conversation is about a problem involving 10 grams of oxygen gas undergoing various processes and the questions that arise from it. The initial pressure, temperature, and volume are given, and the final pressure for the first process is halved. The first question asks for the temperature at the end of the process, while the second, third, and fourth questions pertain to the amount of work done in each step. The final process involves an isobaric expansion to the original volume, and the final question asks for the work done in this step. The conversation also includes discussions on how to solve for the temperature and work using the given equations. Part C remains unsolved as the initial volume is not given.
alireza83
I need help guys. I don't have any idea what to do for this question
10 grams of oxygen gas at an initial pressure of 2.5 atm. and a temperature of 25 C
undergoes an isochoric cooling until the pressure is halved.
(a). What is the temperature at the end of the process?
(b). How much work has been done in this step? Next, the gas is isothermally compressed to its original pressure.
(c). What is the volume at the end of the compression?
(d). How much work has been done in this step? Finally, the gas undergoes an isobaric expansion to its original volume.
(e). How much work has been done in this step?ne in this step?
If you know
[tex]\frac{P_1 V_1}{T_1} = \frac{P_2 V_2}{T_2}[/tex]
and the volume is the same, then I think you can find T2. The final pressure P2 is half of the initial pressure P1
^^^^Exactly, so here's how you set it up (hope this helps)
T2 = ( P2 / P1 ) * T1
*Don't forget to convert to Kelvins during the calculations and remember to subtract 273 afterwards. For Part B, my question to you is : Is any Work done during a Isochoric process?
I'm not sure how you tackle part c as the volume isn't given initially in the problem.
I'm assuming you use : P1V1 = P2V2 & Work = -nRT*ln(Vf/Vi)
^^Any Ideas on how to solve part C?
But in order to solve for the work, you need the number of moles in the 10 grams of Oxygen Gas (O2), and you need the Final & Initial Volume.
FAQ: What is the temperature at the end of the process ?
1. What units are used to measure temperature?
The most commonly used units to measure temperature are Celsius (°C) and Fahrenheit (°F). However, in scientific experiments, temperature is often measured in Kelvin (K) as well.
2. How is temperature measured?
Temperature can be measured using various instruments, such as thermometers, pyrometers, and thermocouples. These devices measure the physical properties of materials, such as expansion or electrical resistance, to determine the temperature.
3. What is the relationship between temperature and energy?
Temperature is a measure of the average kinetic energy of the particles in a substance. As the temperature increases, the particles move faster and have more energy. This relationship is known as the kinetic theory of matter.
4. What is the difference between heat and temperature?
Heat and temperature are often used interchangeably, but they are not the same thing. Temperature is a measure of the average kinetic energy of particles, while heat is the transfer of thermal energy from one object to another. In other words, temperature is a measure of the intensity of heat, while heat is a measure of the quantity of energy.
5. How does temperature affect different substances?
Temperature can have various effects on different substances. In general, as the temperature increases, most substances expand and become less dense. However, some substances, such as water, have a unique behavior where they become less dense as they approach their freezing point. Temperature can also affect the physical and chemical properties of substances, such as their melting and boiling points.
