What is the tension in a rope when a monkey accelerates up?
In summary, the tension in the rope will be equal to its weight, mg. When the monkey accelerates upwards with acceleration a, the tension in the rope will increase to mg + ma. This is because the monkey's force of ma in the downward direction is countered by the rope's force of ma in the upward direction, according to Newton's third law. However, when the monkey is hanging or climbing at a steady pace, the tension in the rope will only be equal to the monkey's weight, as the only upward force on the monkey is the upward friction of the rope and the only downward force on the rope is the downward friction of the monkey. Therefore, the tension in the rope should not be shown on the monkey's free
  • #36
haruspex said:
If I understand your notation, ##F_{MR}## means the force the monkey exerts on the rope. Taking T as the force applied on rope, necessarily, ##T=F_{MR}##, regardless of sign convention.
How about the static friction force acting upwards on the monkey's hands/legs from the rope's surface as it climbs up the rope? The rope and monkey's hands interface cannot be smooth else monkey would slip down as it tried to climb up.
Or we are already considering this friction force when we say force exerted by the rope on the monkey? How is tension in rope related to this frictional force? Probably equal since rope is stationary as monkey climbs up.
Likes Steve4Physics
  • #37
I previously (Post #18) pointed out the role of friction, but no one seems to want to refer to friction!
Likes rudransh verma and vcsharp2003
  • #38
@Steve4Physics (taking up as +ve)
1. If tension is the pair of forces which stretch the rope then why do we show in diagrams the tension inwards?
2. Tension is the force applied by monkey on rope. It is pair of outward forces. Magnitude wise ##T=F_{MR}##. But vectorially ##-T=-F_{MR}##.
Can I say ##T=F_{RM}##?
3. What is the meaning of each?
##-T=-F_{MR}##.
##T=-F_{MR}##.
##-T=F_{MR}##.
##T=F_{MR}##.
  • #39
Steve4Physics said:
With this view, the tension doesn’t directly act on the monkey, so it should not be shown on the monkey's FBD.
Very true.
If we look at the monkey as the isolated system in our free body diagram, then surely it's the friction force from rope that's acting on the monkey and the tension force in the rope is not acting directly on the monkey. We shouldn't be caring about the tension force in our free body diagram.
Likes Steve4Physics
  • #40
I don't see that how the monkey is attached to the rope is of any interest. Could be friction, could be the rope is tied around the monkey (do we need to get into how the friction stops the knot coming undone?), or maybe the monkey sits in a light bucket.
Or you could choose to consider the piece of rope the monkey clutches as part of a monkey+rope piece system.
  • #41
##-T=-F_{MR}##.
##T=-F_{MR}##.
##-T=F_{MR}##.
##T=F_{MR}##.
1.
It depends what body is being considered in the FBD. Whether it is something pulled by an end of the rope or the rope itself, it will point away from that body.
2., 3.
'T' is being used to mean two things here.
On the one hand it can mean the tension, which exists everywhere along the rope acting on each short element as a pair of opposing forces rather than as a single force. In this meaning, direction is either outward from each rope element (tension) or inward on it (compression).
On the other hand, it can mean one of that pair at an end of the rope, and it is up to you to decide which of the pair it stands for. When you write a force equation involving tension you are necessarily taking this second view.
I chose above to consider it as the force the monkey exerts on the rope.
  • #42
Did you read the link in @Lnewqban;s Post #26?
Tension is referred to as a ‘force’ but is a bit more complicated than a simple force.
Say we have rope, AB represented as A------B .
Pull A left with a force of 10N and pull B right with another force of 10N.
10N←A------B→10N
The system is in equlibrium and we have an ‘inwards force’ inside the rope, which stops A and B moving apart. This ‘inwards force’ is called the tension.
At the ends, A is being pulled right by tension and B is being pulled left. We say the tension (inside the rope) is T=10N and we represent it by a pair of inwards arrows:
10N←A→--←-B→10N
The forces at point A are: 10N←A→T
The forces at point B are: T←B→10N
(Note, the external applied 10N forces are not called tension, though they are numerically equal to the tension here.)
I don't know what you mean by 'It is a pair of outwards forces.'.
##-T=-F_{MR}##.
##T=-F_{MR}##.
##-T=F_{MR}##.
##T=F_{MR}##.
Sorry, I don't understand the questions.
  • #43
It’s simply the desire to correctly name the actual physical forces which operate.
Also, recognising the role of friction might be important in some (slightly harder) problems, e.g. finding the monkey’s maximum upwards acceleration.
Likes vcsharp2003
  • #44
In the absence of a diagram, it can get confusing to understand the question. The scenario that I had in mind while looking at the question is as below, where frictional force makes sense.
I'm not sure if the scenario of question is different from what I thought.
  • #45
You mean you used T tension as a condition in rope and wrote Tension as a condition is ##T=F_{MR}## whereas I used it as a single force F
Can you show a diagram?
This is understandable but what you are telling is a bit complicated without diagram
Steve4Physics said:
Again Please show a diagram
  • #46
I thought I already had (in Post #42) included diagrams. Here they are again:
10N←A------B→10N (external forces on rope being pulled outwards)
10N←A→--←-B→10N (internal force (tension, T) inside the rope shown)
10N←A→T (forces acting at point A)
T←B→10N (forces acting at point B)
You might like to watch a video I did about tension (the sound is a bit crackly):
  • #47
No i am telling @haruspex to give diagram like you did. But thanks for additional information.
By the way can you tell me when we write something like ##T=F_{MR}## then are we saying ##T## is equal to ##F_{MR}## or the value of ##T## is ##F_{MR}##
  • #48
Shown below is my diagram adapted from @vcsharp2003's. We know that there are two items that exert a force on the monkey, the rope and the Earth. The forces are shown as arrows in the diagram. You can label them any way you wish. We also know that the monkey is moving up at constant speed. That's all you need to answer the question.
Likes vcsharp2003 and Doc Al
  • #49
When we write equalities in physics, we normally mean that the two quantities are identical. Not that they are literally one and the same thing.
We do hold than when two entities are literally one and the same thing, they have the same quantititative measure. So ##F_{\text{MR}}=F_{\text{MR}}## in both senses.
In first year physics, we often play a little bit fast and loose with the distinction between a vector value, a scalar value and a tensor value. We do not even explain to students what a "tensor" is and how it might be considered to have a single numeric value.
So we can casually write that ##T=F_\text{MR}## when we may mean that the downward vertical force (##T##) exerted to anchor the bottom end of the rope is literally the same force that the monkey applies on the rope.
The tension in an ideal rope is the same as the scalar force applied at either end away from the middle.
  • #50
jbriggs444 said:
So we can casually write that T=FMR when we may mean that the downward vertical force (T) exerted to anchor the bottom end of the rope is literally the same force that the monkey applies on the rope.
This casual explanation is making my life very difficult from morning (and now its night time) because what I knew is Tension T's direction when the rope is under stress is upwards and the force applied by monkey is downwards. So ##T=F_{MR}=-mg##
So tension is basically a force that the rope applies back when it is under stress. It is an inward force. Tension T's direction at end points of rope where its attached to the body and ceiling is inwards. Tension is what we pull something with not push.
This video explains nicely how force applied is transmitted from one end of rope to other under tension.
Someone said that tension is pair of opposite forces acting on small rope elements all along the rope cancelling each other. At the ends there is just one force acting inwards. Am I right?
  • #51
I would advise 'asking' rather than 'telling'!
There is no difference, 'is equal to' means having the same value.
But remember, different vectors can have the same magnitude but the vectors will be unequal if their directions are different.
##\vec T## is the tension acting upwards on the rope (where it is hed by the monkey).
##\vec F_{MR}## is the frictional force acting downward on the rope.
The rope is in equilibrium. To be rigorous we should write:
##\vec T+ \vec {F_{MR}}## = 0
which gives
##\vec T = -\vec {F_{MR}}##
Less rigorously we could write this as:
##T = -F_{MR}##
In terms of magnitudes we can write:
##|T| = |F_{MR}|##
If we are using '##T##' and '##F_{MR}##' to represent magnitudes, we should state this to avoid confusion/ambiguity. Then we can write:
##T - F_{MR}=0## which gives
##T = F_{MR}##.
We could also use the unit vector (##\hat k##) but this might be a bit over-the-top for this type of problem.
  • #52
Steve4Physics said:
I would advise 'asking' rather than 'telling'!There is no difference, 'is equal to' means having the same value.
which gives
##T = -F_{MR}##
##|T| = |F_{MR}|##
##T = F_{MR}##.
Yes! Thank you! @haruspex should understand this. People like us are in their elementary stage. Sticking to one rule will help in long run like something like up is +ve sign convention and not changing signs every time. Writing casually in my views should be avoided because it hinders in what one is trying to say. It should be rigorous.
  • #53
which gives
##T = -F_{MR}##
I agree with first two equations, but the one following "less rigorously" can be confusing to a novice. That's because a symbol with an arrow over it denotes a vector whilst the same symbol without the arrow denotes the magnitude of the vector. In one dimension, the "less rigorous" approach that you show confuses the magnitude of the vector, which is always positive, with the component of the vector which could be positive or negative. All this can easily be sorted out by using, rigorously, unit vectors and subscripts for components, both which are routinely dropped in the less rigorous approach.
Starting with
##\vec T+ \vec {F}_{MR}=0##, we rewrite the one-dimensional vectors in terms of their components as
##T_y~\hat y+ F_{MR,y}~\hat y=0##
Here is where we drop the unit vectors and write
##T_y+ F_{MR,y}=0~\implies~T_y=-F_{MR,y}##
which shows that when two one-dimensional vectors add to zero, their components have the same magnitude and opposite signs.
The interpretation of vectors in FBDs is that the label of the arrow denotes the magnitude while the direction of the arrow denotes the direction of the vector. So if we have the FBD of this, we would see two vectors labeled ##T## and ##F_{MR}## pointing in opposite directions.
Starting again with
##\vec T+ \vec {F}_{MR}=0##, we rewrite the one-dimensional vectors in terms of their magnitudes as
##\vec T=T~(+\hat y)~;~~ \vec {F}_{MR}=F_{MR}~(-\hat y)##
Then
##T~(+\hat y)+F_{MR}~(-\hat y)=0##
##T~(+\hat y)=-F_{MR}~(-\hat y)=F_{MR}(+\hat y)##
Again we drop the unit vectors and write
##T=F_{MR}##
which shows that when two vectors point in opposite directions and add to zero, they have the same magnitude.
In short, when we write an equation relating two or more one-dimensional vectors, we have to be clear whether the equation relates components or magnitudes.
  • #54
That is still answered by my last option, consider the piece of rope the monkey clutches as part of a monkey+rope piece system.
Likes vcsharp2003
  • #55
Yes, but for tension it is a little different. Tension and force have the same dimension, but the notion of direction is quite different. Tension is not a vector.
Many students start off thinking that if there is a force magnitude F pulling on each end of a rope then the tension should be 2F. Strictly speaking, tension could have been defined that way, but it is not. So saying they have the same magnitude is just (the universally agreed) convention.
More easily wished than done. In 3D problems, what could the fixed rule be for horizontal forces? Or maybe the context is gravity-free, so there is no vertical. And advisors on PF don't know what the students have been taught to do, and don't all have the same ways of working.
Likes Lnewqban
  • #56
Oh yes! That’s what I was missing. Tension is scalar. In whatever direction(angle we change) we pull the rope that is tied to a weight through a pulley, tension doesn’t change.
Can you elaborate?
  • #57
Lnewqban said:
Any flexible connector, such as a string, rope, chain, wire, or cable, can exert pulls only parallel to its length; thus, a force carried by a flexible connector is a tension with direction parallel to the connector. It is important to understand that tension is a pull in a connector. In contrast, consider the phrase: “You can’t push a rope.” The tension force pulls outward along the two ends of a rope. Consider a person holding a mass on a rope as shown...”
So you mean tension is pulling the hand of the holder and the weight inwards. That is what tension is . It is a pulling force.
  • #58
Sorry, rudransh, I can't understand your question.
That statement that you have just posted is only a quotation from this link:
https://courses.lumenlearning.com/physics/chapter/4-5-normal-tension-a
What is about the concept of tension that is still troubling you after so many posts of this thread?
The way I understand the tension inside the rope (perhaps incorrectly):
The cohesion of the fibers, which is the natural attraction of similar molecules for each other, resists the action of the forces trying to separate those so many molecules.
The molecules of that rope do not allow much distance to grow between each other, reason for which the rope does not stretch as much as a rubber band or metal spring would do under stress.
If the magnitude of the external forces acting on the rope becomes greater than the cohesion of all the molecules contained in the plane of any cross-section of the rope, those molecules get separated and the rope breaks.
The rope of your example is no more no less than a solid link between the two forces in question: the static weight of the monkey and the reaction force at the anchor located at the top.
It could be long, short, that does not change the magnitude and direction of those external forces.
Or it could be a chain, a wire-rope, an ivy, a bungee cord, a spring, a long piece of wood, or any other thing able to transfer forces, creating internal tensions in the process.
Even if there is no rope and the monkey directly grabs the anchor or branch, its weight and the reaction at the point of anchorage would still be the same.
Likes vcsharp2003
  • #59
I just want to be verified that I understand it right. All rope does when you say “The tension force pulls outward along the two ends of a rope” is that it is pulling inwards what is attached to it on both ends when the rope is under tension?
  • #60
The attachment points pull outward on the rope. The rope pulls inward on the attachment points. For an ideal (massless) rope, the magnitudes of all four of those forces are identical.
One can see that they are identical by applying Newton's third law at the two attachment points ends and Newton's second and third laws in a daisy-chain all the way along the rope.
  • #61
I believe that I did not say that, it is a statement in that linked website.
The internal forces in the rope ("molecular tension") prevent the rope from being ripped apart by the external forces acting at both ends.
The internal forces are resistive, are a natural reaction to external energy.
If the rope breaks, the energy of the external forces did the destructive work.
  • #62
Lnewqban said:
I believe that I did not say that.
I mean the link says that.
  • #63
As the magnitudes of external forces and internal forces are similar, they use tension and force alternately.
Again, I may be wrong.
  • #64
To @rudransh verma :
The important thing to remember about tension in a rope is that a force is associated with it. To find its direction, first you need a system on which this force acts. Once you have defined the system, the force due to tension acts along the rope or string in a direction away from the system. In short, you cannot push with a rope.
For example, in the climbing monkey problem we can choose to define the monkey as the system (see post #48.) The force due to the rope tension is up and away from the monkey. We can also choose as our system a 10 cm piece of rope above the point of contact with the monkey's hand. In that case, there is a down force on the 10 cm piece of rope due to the monkey's hand (equal and opposite to the one exerted by the rope on the monkey and away from the system), and an "up" force, also away from the system exerted by the rope that is above the 10 cm system. We can also choose a piece of rope of any length as the system. There will be two forces at each end of the system, both pointing away from the system.
At this stage, I think that's all you need to know to figure out the direction of the force due to tension in order to use it in free body diagrams. Knowing the details of the molecular forces that give rise to this force is not necessary for drawing and interpreting FBDs just like it is not necessary to know exactly how a car engine works in order to drive one to a friend's house. Defining the system before you attempt to draw the force due to tension is as important as knowing what a car looks like before you get in it.
Likes vcsharp2003, rudransh verma, Doc Al and 1 other person
  • #65
Can you clarify my post#50
  • #66
You said you do not want casual. Ask and you shall receive.
For Tension as a stress in a rope, it has neither direction "up" nor direction "down". It has only direction "vertical". In three dimensions, tension has a coordinate representation as a 3 by 3 matrix. If you choose a coordinate system in which the first coordinate is vertically aligned with the vertical rope, the stress is uniform and the cross-sectional area of the rope is ##a## then this tensor will be $$
\begin{bmatrix}
-T/a & 0 & 0\\
0 & 0 & 0\\
0 & 0 & 0
\end{bmatrix}$$More generally, if one chooses a poorly aligned coordinate system, the tension will manifest as two or three negative terms on the main diagonal that sum (via the Pythagorean theorem) to the magnitude of the tension (per unit area) in the rope.
If one wants to recover the force transmitted by a uniform tension through an imaginary dividing line in the rope, one multiplies the stress tensor by the directed area of a cross-section through the rope.
A "directed area" is a planar area represented as a vector. The area is represented by the magnitude of this vector. The direction is represented by the direction of the vector (normal to the plane). If one multiplies a 3x3 stress tensor by a 1x3 directed area, one recovers a 3x1 force vector. That vector is the force resulting from the tension acting through the area.
Even less casually, tension need not be uniform across the rope. One could instead take a surface integral, adding up local stress times incremental directed area across a surface that bisects the rope.
What this means for a rope attached to the monkey is that you multiply the stress tensor in the body of the rope by a directed area pointing outward at the monkey and recover a vector force that points inward toward the rope. This is the force of rope on monkey.
More casually, we have a useful invariant. No matter where we choose to slice an ideal massless rope with a directed surface between the potion exerting a force and the portion on which a force is being exerted, the resulting vector force will be aligned with the rope and will have a direction opposite to the direction of the slice. [It does not matter whether you slice neatly at right angles, diagonally or along a jagged curve. The result is always the same -- aligned with the rope, not with the cut].
Casually speaking, yes.
Yes, there is one force from rope on attached object. Though, of course, Newton's third law still applies. There is an equal and opposite force from attached object on rope.
  • Wow
Likes kuruman
  • #67
Ok! Very clever:oldsurprised:. Thanks man!
