What is the tension in each part of the rope
In summary: Also, with practice, you'll get a feeling for when an expression is getting too big and you should find a different way to attack the problem.
donotremember
31
To keep Robin from being captured, Batman tosses him out of a third-story window, knowing that a 17.0m rope hangs slack between hooks of equal height on adjacent buildings 13.0m apart. Robin grabs the rope and hangs on at a point 5.0m from one end. Assuming that Robin's mass is 45.0kg and the rope withstands the initial impulse, what is the tension in each part of the rope when equilibrium is established?
I believe that this question can be simplified to the following:
(Think of this as a triangle)
Find T2 and T1:
.......13m
..5m..\......./
....\.../...12m
......V
......45kg or (45kg)(9.8m/s^2) = 441NWhere the 5m rope is T2 and the 12m rope is T1
From the law of cosines we have the following angles
67.4 (or 112.6).........22.6
...112.6...\-/...22.6
Step 1 find a relation between T2 and T1:
The system is in equilibrium so the x components cancel
T2cos112.6 + T1cos22.6 = 0
T2(-0.384) = -T1(0.923)
T2 = 2.4T1
Step 2 use the relation found in step one to solve for T1
The system is in equilibrium so the y components added equal the weight:
T2sin112.6 + T1sin22.6 = 441N
2.4T1sin112.6 + T1sin22.6 = 441N
2.215T1 + 0.384T1 = 441N
T1 = 169.6N
and given step 1 T2 = 407N
The answers given in my book are
T1 = 1.5 X 10^2 N
T2 = 3.6 X 10^2 N
Note that they satisfy the relation T2 = 2.4T1
Also note that gravity is calculated as being 9.8m/s^2 in my book (which I have used)
I'm not sure about your numbers, but your thought process is pretty good. A few things...
you lost percision in your answer when you pluged in numbers too early. You want to have a final algebric expression, then plug. It's easier, more precise, and saves paper. Develop this skill now and it will make physics much easier.
show me how you would have done it
flatmaster gave you advice not to plug the number in the beginning of the calculation.
you change the value of cos 112.6 and cos 22.6 at the second line of your calculation.
It's much better if you just leave them and plug the number at the end of calculation.
You are right. The answers in the back of the book are wrong. Although working exclusively algebraically is incredibly important and it is what you will be doing for the rest of your career. For example, in this case we find that the final expression for T2 is:
[itex]T_2=\frac{mg}{\frac{sin(\theta_2)}{tan(\theta_1)}+cos(\theta_2)}[/itex] where theta_1 and theta_2 are the inside of the triangle:
\theta_2|theta_1/
..T2.\...|.../...T1
...And that's enough ASCII art for one lifetime.
Thanks for your help. I usually put numbers in early to eliminate variables and reduce the size of the expression. When I try to express the entire problem in terms of variables, sometimes but not always, I end up with a huge expression that takes several lines and I end up copying wrong. I guess its an art to finding the most elegant solution.
It's usually recommended to use your variables throughout, only putting numbers in at the final step. It's neater (really!), and it's much easier to see what's going on in your work.
Related to What is the tension in each part of the rope
What is tension and how is it measured?
Tension is a force that is exerted on an object. It is measured in units of Newtons (N) using a tension meter or a spring scale.
What factors affect tension in a rope?
The tension in a rope is affected by the force applied to the rope, the length of the rope, and the material and thickness of the rope.
How is tension calculated in each part of a rope?
In order to calculate the tension in each part of a rope, the total force applied to the rope must be divided by the number of parts in the rope. For example, if 100N of force is applied to a rope with 4 parts, each part will have a tension of 25N.
What happens to the tension in a rope if it is pulled from both ends?
If a rope is pulled from both ends, the tension in the rope will increase due to the added force being applied. The tension will be distributed evenly throughout the rope.
Can the tension in a rope be greater than the force applied to it?
Yes, the tension in a rope can be greater than the force applied to it. This can happen if the rope is being pulled in different directions or if there are multiple forces acting on the rope.
9K
41K
