What is the theory of gravitons
In summary, gravitons are hypothetical particles that are believed to be the force carrier for gravity in a quantum field theory. However, our current understanding of gravity using General Relativity does not accurately describe gravitons. There have been attempts to quantize gravity, but it has not been successful yet. If gravitons were discovered, it could potentially mean a major breakthrough in physics and would contradict some major theories. Extra dimensions also play a role in some theories of gravity, such as string theory, where gravitons are described as closed loops in higher dimensions. However, the notion of gravity as a force is still debated, as it is believed to be the curvature of spacetime according to Einstein's theory of General Relativity. The search
Nwachuku Chimaobi
Gravitons are particles believed to be the cause of gravity but can anyone tell me their principle and how they work
The graviton would be force carrier particle of gravitation, much like how the photon is the force carrier particle for the electromagnetic force (the other 2 forces have their own force carriers). These force carriers are the result of a particular type of theory known as Quantum Field Theory (QFT), which is what the current standard model of particle physics is based on. The details are well above even my head though.
Unfortunately QFT does not accurately describe gravitation. The graviton is a hypothetical force carrier that is believed to exist if gravitation is quantized like the other forces are. As it is, we're still using General Relativity, which isn't a quantum theory (meaning that it doesn't describe gravity as being quantized).
Here are some links to more information:
https://en.wikipedia.org/wiki/Graviton
https://en.wikipedia.org/wiki/Force_carrier
There have been attempts to quantize gravity, you may find this wiki article interesting.
https://en.wikipedia.org/wiki/Quantum_gravity
Nobody seems to have nailed it yet though.
Gravitons would exist in such a theory if somebody did, but until then they are hypothetical.
As gravitons are currently hypothetical, how might they be discovered?
And if they were, what could this discovery potentially mean to the wider physics community and The Standard Model? Which major theories would in come in direct contradiction with?
Also if someone could elaborate on how extra dimensions come into play concerning gravity then it would be appreciated.
PS. I am a high school student studying Physics.
Likes hsdrop
I can take a shot at answering this one at least.
With the view of gravity as a "force", when compared to the other 'fundamental forces' (Such as Electromagnetic and Weak, also the "Strong" nuclear Force) is incredibly weak by comparison. An example is in the ability for a magnet on a string hanging downwards by the gravity of the entire Earth may be deflected by a small other magnet, whilst the gravity of a 10 tonne weight won't even make the slightest visible difference.
Physicists have attempted to understand why there's such a huge difference and called it "the hierachy problem".
As such, there have been a number of theories and ideas attempting to explain and solve this "hierarchy problem" - a popular one being linked with "Loop Quantum Gravity" - based on a string theory, which in essence, basically suggests that the fundamental force carrying particles (i.e. photons for light, W and Z for Weak force, pions for strong force) are made of tiny fundamental strings that vibrate in certain ways.
According to the theory, Gravitons are also such strings, but are closed loops - the ends of the strings can join together. Whereas other strings have at least one 'end' always attached to our familiar 3+1 dimensional spacetime - these loops, are no longer so grounded and are then free to 'float away' in a higher dimensional space.
Therefore (according to the theory) despite gravitons actually possessing more similar energies as their counterparts - so many are lost to this higher dimensional space, that the resulting forces experienced in our 3+1d spacetime appear so much weaker.
___
A lot of the description and language used is non-scientific and potentially misleading. I apologise for this. The attempt was to give a visual idea, rather than a technical explanation.
The notion of gravity as a force is where the problem arises. According to Einstein, gravity is not a force. It is merely the curvature of spacetime in the presence of mass. The fact all bodies fall at the same rate in a gravitational field illustrates this point. Were gravity a force, heavy objects would fall proportionately faster than light objects in a gravitational field. There is no need for a carrier particle [graviton] to convey a force where none exists.
Lewis123 said:
As gravitons are currently hypothetical, how might they be discovered?.
We may be able to detect quantized gravity using gravity wave telescopes. As two huge objects get closer and closer to each other, general relatively predicts a smooth transition, no energy levels. If gravity is quantized, then there should be discrepancies at the last instant of a black hole merger. They should only be able to radiate gravitational energy away in packets, so the transition would not be smooth.
Wrong.
The strength of gravitational attraction in a quantum gravity theory would depend on strength of coupling of all other fields to the graviton field. As you correctly noted, we know from experiments that it is proportional to mass (more correctly, stress-energy tensor), and GR's only equation says precisely that.
Thus, any sensible quantum gravity theory which wants to match observations posits that this coupling is also proportional to stress-energy tensor of these "other fields", and it all works just fine.
The difficulties are elsewhere: renormalization procedure does not work for gravitons.
There is. "Classical" (i.e. non-quantum) theories are mathematically incompatible with quantum ones. GR is "classical". Standard model is quantum.
Unless gravity is emergent in the quantum theory ;)
The attempt to build a quantum field theory of gravity using point like gravitons does not seem to work. Instead, the modern understanding is that spacetime is not a fundamental notion, and that gravitons must be described by a 2d conformal field theory on an auxiliary space (a Riemann surface) called the world-sheet. In certain limits, this confromal field theory describes strings propagating in spacetime, but in general there is no such interpretation. The theory of gravitons is formulated as a 2d conformal quantum field theory on Riemann surfaces.
FAQ: What is the theory of gravitons
What is the theory of gravitons?
The theory of gravitons is a scientific concept that proposes that gravity is a result of the exchange of particles called gravitons. These particles are believed to be carriers of the gravitational force, similar to how photons are the carriers of the electromagnetic force.
How does the theory of gravitons relate to the theory of general relativity?
The theory of gravitons is an extension of the theory of general relativity, which explains gravity as the curvature of space-time caused by massive objects. The theory of gravitons helps to reconcile the principles of general relativity with the principles of quantum mechanics.
Have gravitons been observed or detected?
As of now, gravitons have not been directly observed or detected. However, scientists have been able to indirectly detect the effects of gravity, which supports the existence of gravitons. Research is currently ongoing to develop technologies that can directly observe gravitons.
Can gravitons explain the phenomenon of dark matter?
Gravitons are not believed to be related to the phenomenon of dark matter. Dark matter is thought to be made up of particles that do not interact with light, while gravitons are believed to be carriers of the gravitational force. Therefore, gravitons cannot explain the existence of dark matter.
What implications does the theory of gravitons have for our understanding of the universe?
The theory of gravitons has significant implications for our understanding of the universe. If proven to be true, it would provide a more complete understanding of the fundamental forces of nature and help to reconcile the principles of general relativity with quantum mechanics. It would also aid in the development of new technologies and potentially open up new avenues for scientific research.
