What is the time taken by a pulse generated at the bottom of a string to reach the top?
In summary, the time taken by a pulse generated at the bottom of a string to reach the top depends on the properties of the string, including its tension and linear density. The speed of the pulse can be calculated using the formula \( v = \sqrt{\frac{T}{\mu}} \), where \( T \) is the tension and \( \mu \) is the linear density. The time can then be found by dividing the length of the string by the speed of the pulse, leading to the equation \( t = \frac{L}{v} \).
hdje
In a test the time taken by a pulse (generated at the bottom) to reach the top of the string was asked. Mass per unit length was 0.001kg/m and length was 1m.
v = √(T/μ)
I have been taught that speed of pulse is v = √(T/μ), but here tension varies at each point therefore I cannot just simply apply the formula. I think integration would be needed, I tried but ended up nowhere. Can someone help me find the time?
Can you post the text of the question?
A string of length 1 m and mass per unit length o.oo1kg/m is hanging vertically. A small pulse is generated at its lower end. The pulse reaches the top end in approximately: (g=10m/s^2)
(1) 1/sqrt(10) s
(2) 3/sqrt(10) s
(3) 2/sqrt(10) s
(4) sqrt(5)/2
As the tension is not given, I would assume that you need to take it as produced by the string's own weight. It will increase linearly from zero at the bottom to the full weight at the top.
So how long would it take the pulse to get from a point distance y from the bottom to a point y+dy from the bottom?
You could solve it without having to do an integral if you find out the relationship between pulse velocity at position y and the distance travelled by the pulse up to that position. You may be familiar with such a relationship from previous study of motion.
I think I got it, but with integration. Correct me if I'm wrong.
hence the answer will be (3) 2/sqrt(10) s
It is v and not dv in your first formula:
It is v=dy/dt and not dv.
But the answer is right.
Once you see that the square of velocity is proportional to the distance travelled you may remember the same relationship holds for uniform accelerated motion with zero initial velocity. So the average velocity is half the final velocity. And the time is the length of the string divided by the average velocity.
FAQ: What is the time taken by a pulse generated at the bottom of a string to reach the top?
What factors determine the time taken by a pulse to travel up a string?
The time taken by a pulse to travel up a string is primarily determined by the tension in the string, the mass per unit length of the string, and the length of the string. Higher tension and lower mass per unit length result in faster pulse propagation.
How do you calculate the speed of a pulse on a string?
The speed of a pulse on a string can be calculated using the formula \( v = \sqrt{\frac{T}{\mu}} \), where \( v \) is the speed of the pulse, \( T \) is the tension in the string, and \( \mu \) is the mass per unit length of the string.
Does the amplitude of the pulse affect the time taken to reach the top of the string?
No, the amplitude of the pulse does not affect the speed at which it travels. The time taken for a pulse to reach the top of the string is independent of its amplitude.
How does the length of the string affect the time taken for the pulse to travel?
The time taken for a pulse to travel the length of the string is directly proportional to the length of the string. If the length of the string is \( L \) and the speed of the pulse is \( v \), then the time taken \( t \) is \( t = \frac{L}{v} \).
What is the effect of increasing tension on the time taken by the pulse to reach the top?
Increasing the tension in the string increases the speed of the pulse. As a result, the time taken for the pulse to reach the top of the string decreases. This is because the speed of the pulse is proportional to the square root of the tension.
