What is the total amount of work done by friction?
So why would you integrate over x?As for the range, I don't believe there should be one--should it not just be indefinite?You are asked for the total work done as the rope of length L slides off, not some unknown length x of... something. So why would you integrate over x?In summary, the problem involves a rope of mass M and length L resting on a horizontal table with a coefficient of kinetic friction μk. The work done by friction as the rope slides off the table is calculated by considering a small section of rope and determining its mass dm and the magnitude of the friction force acting on it. The total amount of work done by friction is then found by integrating the small amount of
OGBJ
Consider a rope of mass M and length L, resting on a horizontal table, as shown in the figure. The coefficient of kinetic friction between the table and the rope is μk. Let's consider the work that's done by friction as we slide the rope off the table.
a.) Consider a small section of rope. What is the mass dm of that small section. (You can use the following variables in your answer: M, L, dx)
ANSWER: dm = M(dx/L)
c.) What is the magnitude of the friction force acting on this small piece of rope? (You may use the following variables in your answer: M, L, dx, μk)
ANSWER: μkMg(dx/L)
d.) Calculate the small amount of work dW that the friction force does in sliding a small section of the rope dm initially located a distance x from the edge of the table off the table.
ANSWER: dW = -μkxMg(dx/L)e.) What is the total amount of work done by friction as the entire rope slides off the table?
dW = (-μkxMg)(dx/L)
I know I need to integrate both sides of the relevant equation to solve for W. I thought all the terms but x and dx could be treated as constants, so I took them out of the integral and was left with:
W = (-μkMg/L)∫xdx = (-μkx^2Mg)/(2L).
However, this is not the correct solution, which leads me to assume that I can't just take the other terms out of the equation like that. I'm not sure how to treat the problem otherwise, though. Any help would be appreciated. Thanks.
OGBJ said:
= -μkx^2Mg/2L.
Is that exactly how you entered it in an online tool? Do you understand that what that says is "μkx2(Mg/2)L"?
Try using parentheses correctly.
Edit: and as berkeman noticed and I should have, x should not appear in the answer.
Welcome to the PF.
Is this a correct answer, or just your answer so far? The amount of work to slide the mass dm off the table depends on the distance to the end of the table from that dm, not on dx...
EDIT -- Or maybe you just left a term off of this equation...?
No. I believe I formatted it correctly in my attempted submission. Here's what it looks like in the tool:
f09rh02
(I think I failed to get the image to embed. Here's the a direct link to it if needed: https://imgur.com/a/ZE8iG)
Apologies for the incorrect formatting in the body of the post. I'll clean that up now.
Welcome to the PF.
Thanks. The answers to parts a)->d) have been entered into and accepted by WebAssign. Here's where I am so far; hopefully this clears things up: https://imgur.com/a/FFhZI
Edit: Why should x not appear in the answer? Shouldn't it be expected that work increases as distance does? Also, as per part a, the M(dx/L) portion of dw=mukxgM(dx/L) can be interpreted as dm, since that's what's solved for in part a. I'm not certain if that's relevant, but I thought I'd mention it, since I'm pretty confused about where I am in the problem right now.
Please see my edited post and reread berkeman's carefully. What is the range of the integral?
Likes berkeman
I don't think I'm fully understanding why x shouldn't be in the answer. Here's my edit that I made just after you replied: Why should x not appear in the answer? Shouldn't it be expected that work increases as distance does? Also, as per part a, the M(dx/L) portion of dw=mukxgM(dx/L) can be interpreted as dm, since that's what's solved for in part a. I'm not certain if that's relevant, but I thought I'd mention it, since I'm pretty confused about where I am in the problem right now.
As for the range, I don't believe there should be one--should it not just be indefinite? If it was definite the only range I could see is 0->x.
Edit: If the range was 0->x nothing would change since when x = 0 the whole equation is equal to zero.
I understand that the problem is trying to guide you to approach the problem in a particular way, but maybe solving it a different way will help you gain some intuition.
When I first saw the overall problem, I approached it this way... For each position of the rope as it slides off the table, you can calculate W(x) for a small displacement dx. In this case, x is the length of the rope still left on the table. So just write the equation for W(x) and integrate it from x=L to x=0 (to correspond to the rope being pulled off of the table). Maybe give that a try to see what the answer should look like.
You are asked for the total work done as the rope of length L slides off, not some unknown length x of it.
Ah. Integrating using L as my limit rather than x solves my problem. -mukMgL/2 is my final answer! Thank you.
Likes berkeman
Related to What is the total amount of work done by friction?
The total amount of work done by friction is the product of the force of friction and the displacement of the object in the direction of the force.
What factors affect the amount of work done by friction?
The amount of work done by friction is affected by the coefficient of friction, the normal force, and the displacement of the object.
How is work done by friction calculated?
The work done by friction is calculated by multiplying the force of friction by the displacement of the object in the direction of the force.
Can the work done by friction be negative?
Yes, the work done by friction can be negative if the displacement of the object is in the opposite direction of the force of friction.
How does the work done by friction affect the energy of the system?
The work done by friction converts mechanical energy into heat, resulting in a decrease in the overall energy of the system.
