What is the true impact speed when two cars collide head-on at 50mph?
  • Thread starter AJ_2010
  • Tags
    Cars Head
In summary, the impact speed in a head-on collision between two identical vehicles traveling at 50mph is 50mph. This is because each vehicle is going through a transition of 50mph down to 0mph in the space of a crumple zone. However, it can also be argued that the impact speed is 100mph if looking at the frame of reference of one of the vehicles, as the other vehicle is approaching at 100mph. The term "impact speed" is open to interpretation and can depend on the frame of reference. The amount of energy involved in the impact is the same regardless of the reference frame, but the force and duration of the impact may vary. In a head-on collision with a stationary wall,
  • #36
torquil said:
According to the sources I've seen: for a given road, a lower speed limit leads to fewer deaths and less emissions.
Why? Less kinetic energy involved and less energy dissipation per unit distance.
However, it could be argued that since cars have a lower fuel efficiency at lower speeds it is likely that more HARMFUL Carbon Monoxide might be released.
  • #37
If I can drive the same car at either 100km/h or 80km/h on different gears at the same engine RPM, it's pretty obvious which speed is more efficient, even per unit distance. This happens because everything is approximately the same within the car, apart from the much larger air resistance...
I think that considerations about engine efficiency vs RPM (which shouldn't cause very much difference anyway since cars have gear boxes), are second order effects that cannot "compete" with the unavoidable increase in energy dissipation caused by the rapidly increasing air resistance as speed is increased (unfortunately, it increases more rapidly than v to the first power...)
There is no question that a car with a gear box and a combustion engine, if constructed to do so, will be more efficient (less energy loss per unit distance) e.g. at 80km/h than at 100km/h.
Unfortunately, as interesting as this discussion is, I guess it belongs in a different thread.
