- #36
mfb
Mentor
- 37,265
- 14,098
As a standard deviation, 0.2 is easy to achieve and 0.1 might be possible (all in mm).truesearch said:I am concerned when I read in post 6 (a PF Mentor) that measurements can be made to within +/- 0.1mm using a mm scale.
As an example for 0.2 standard deviation, this means that 0.3 is usually (~70%) read somewhere between 0.1 and 0.5. It is sufficient to see that 0.3 is smaller than 0.5, but not close to 0, to do this.
0.5 should usually be read somewhere between 0.3 and 0.7 - which is everything not close to a mark on the scale.
If you want to give some "upper bound" for the error, you should use larger values, of course. But an upper bound is not always well-defined (apart from digital displays). And if you want to use the marks on the scale, you should format your numbers like [itex]0.3^{+0.7}_{-0.3}mm[/itex]
