What is the upward force exerted on the board by the support?
In summary, a long uniform board weighing 62.6 N is balanced on a support at its mid point by two children weighing 317.0 N and 500.0 N. The upward force exerted on the board by the support is equal to the sum of the weights of the children and the board. This can be calculated using the equation F=ma.
alfredo24pr
49
A long uniform board weighs 62.6 N (12.5 lbs) rests on a support at its mid point. Two children weighing 317.0 N (63.4 lbs) and 500.0 N (100.0 lbs) stand on the board so that the board is balanced. What is the upward force exerted on the board by the support?
F=ma
I do not know even where to start. This is confusing
Is there a reason why you wouldn't believe the equal and opposite force on the fulcrum wouldn't be the force of the sum of the weights (including the board)?
lol! Is it really that simple?
yes it was the sum! I did not believe it was that simple. Thanks!
and I do not know what to do.
The upward force exerted on the board by the support can be calculated using Newton's second law, which states that force is equal to mass multiplied by acceleration (F=ma). In this case, the board is not accelerating, so the net force on the board must be zero. This means that the upward force exerted by the support must be equal in magnitude to the downward forces exerted by the children.
To calculate the downward forces, we can use the weight of each child (mg), where g is the acceleration due to gravity (9.8 m/s^2). So the downward force exerted by the first child is 317.0 N and the downward force exerted by the second child is 500.0 N. Since the board is balanced, these two forces must be equal, so the upward force exerted by the support must also be 317.0 N and 500.0 N.
To find the total upward force exerted by the support, we simply add these two forces together: 317.0 N + 500.0 N = 817.0 N. So the upward force exerted by the support is 817.0 N.
FAQ: What is the upward force exerted on the board by the support?
What is upward force and how is it defined?
Upward force is a type of force that acts in the opposite direction of gravity, pushing objects away from the Earth's surface. It is typically measured in units of newtons (N) and is defined as the force required to counteract the force of gravity on an object.
How is the upward force exerted on a board by the support calculated?
The upward force exerted on a board by the support can be calculated using the formula F = mg, where F is the upward force, m is the mass of the board, and g is the acceleration due to gravity. This formula takes into account the weight of the board and the force needed to counteract it.
How does the angle of the support affect the upward force on the board?
The angle of the support can affect the upward force on the board by changing the distribution of weight and the direction of the force. For example, if the support is at a steeper angle, more of the board's weight will be supported, resulting in a greater upward force.
Can the upward force on a board be greater than the weight of the board?
Yes, the upward force on a board can be greater than the weight of the board. This can occur when the support is at a steep angle or when additional forces, such as friction or air resistance, are also acting on the board.
How does the material of the support affect the upward force on the board?
The material of the support can affect the upward force on the board by determining how much friction or resistance the support will provide. For example, a smooth surface will provide less friction and result in a smaller upward force compared to a rough surface with more friction.
