What Is the Value of a+b If (a+√(a²+1))(b+√(b²+1))=1?
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, POTW stands for "Problem of the Week" and #251 refers to the 251st problem posted on the MathHelpBoards forum. It can be found by searching for "MathHelpBoards POTW #251" on any search engine. The value of a+b in the solution is not explicitly given, but the solution provides a general method for solving the problem. The solution involves using algebraic manipulation and the properties of exponents, and it may be helpful to review basic algebra concepts and exponent rules. There is no specific formula or equation used in the solution, and alternative methods may exist. However, the solution provided by MathHelpBoards is a comprehensive and efficient approach.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Suppose that for two real numbers $a$ and $b$ the following equality is true:
$(a+\sqrt{a^2+1})(b+\sqrt{b^2+1})=1$.
Find the value of $a+b$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution::)
1. kaliprasad
2. lfdahl
3. Theia
Solution from Theia:
If the product of two numbers is equal to one, they have to be reciprocals. So if
\(\displaystyle a + \sqrt{a^2 +1} = u \qquad \Rightarrow \qquad a = \frac{u^2 - 1}{2u}\)
then
\(\displaystyle b + \sqrt{b^2 +1} = \frac{1}{u} \qquad \Rightarrow \qquad b = \frac{u^{-2} - 1}{2u^{-1}}\).
Now, by direct simplification one obtains
\(\displaystyle a + b = \frac{u^2 - 1}{2u} + \frac{u}{2} \cdot \frac{1 - u^2}{u^2} = \frac{u^2 - 1}{2u} + \frac{1 - u^2}{2u} = 0\).
FAQ: What Is the Value of a+b If (a+√(a²+1))(b+√(b²+1))=1?
What is POTW #251 and how can I find it?
POTW stands for "Problem of the Week" and #251 refers to the 251st problem posted on the MathHelpBoards forum. You can find it by searching for "MathHelpBoards POTW #251" on any search engine.
What is the value of a+b in the solution to POTW #251?
The value of a+b in the solution to POTW #251 is not explicitly given, as it depends on the specific values of a and b in the problem. The solution provides a general method for solving the problem and finding the value of a+b.
Can you explain the solution to POTW #251 in simpler terms?
Yes, the solution to POTW #251 involves using algebraic manipulation and the properties of exponents to find the value of a given expression. It may be helpful to review basic algebra concepts and exponent rules before attempting to solve the problem.
Is there a specific formula or equation used in the solution to POTW #251?
No, the solution to POTW #251 does not involve a specific formula or equation. Rather, it utilizes algebraic manipulation and exponent rules to simplify the given expression and find the value of a+b.
Are there any alternative methods for solving POTW #251?
Yes, there may be alternative methods for solving POTW #251. However, the solution provided by MathHelpBoards is a comprehensive and efficient approach that can be applied to similar problems involving algebraic expressions and exponents.
