What is the Value of f(2009) in the Given Recursive Sequence?
  • MHB
  • Thread starter Albert1
  • Tags
    Sequence
In summary, to find the number of a sequence, use the formula for the nth term. The pattern in a sequence is how the numbers change from one term to the next. To determine if a sequence is arithmetic or geometric, check the difference or ratio between consecutive terms. You can find the number of a sequence without the formula by using the differences or ratios between terms. To find a missing term, use the known terms to find the difference or ratio.
Albert1
1,221
$f(5)=10$
$f(n+3)=\dfrac {f(n)-1}{f(n)+1},\,\, for \,\, all \,\,n\in N$
find f(2009)
Mathematics news on Phys.org
Re: find number of a sequence
Albert said:
$f(5)=10$
find f(2009)
because of periodicity: f(5)=10, f(8)=9/11, f(11)=-1/10, f(14)=-11/9; f(17)=10, ...
f(2009)=10
Albert said:
$f(5)=10$
find f(2009)
An equivalent and more simple statement of the problem is: given the difference equation...
$$ a_{n+1}= \frac{a_{n}-1}{a_{n}+1}\ ,\ a_{0}=10\ (1)$$
... find $a_{668}$...
Before trying a 'direct attack' to the non linear d.e. (1) it is better to search that (1) has some periodic solution, i.e. a solution where $a_{n+k}=a_{n}$. Let's set $a_{n+k}=y$ and $a_{n}=x$. We start with k=1 we obtain ...
$$y= \frac{x-1}{x+1}\ (2)$$
... and imposing y=x we arrive to the equation...
$$ x^{2}+1=0\ (3)$$
... which has no real solutions. Setting k=2 we arrive to the [surprisingly simple...] equation...
$$y = - \frac{1}{x}\ (4)$$
... that pratically solves the problem. The (4) indeed indicates that the solution has periodicity 4 and, given $a_{0}$, we have...
$$a_{0}\ ,\ \frac{a_{0}-1}{a_{0}+1}\ ,\ - \frac{1}{a_{0}}\ ,\ -\frac {a_{0}+1}{a_{0}-1}\ , \ a_{0}\ ,\ ...\ (5)$$
In our case is $a_{0}=10$ so that the other terms are $a_{1}= \frac{9}{11}$, $a_{2}= - \frac{1}{10}$, and $a_{3}= - \frac{11}{9}$ . Now 668 is divisible by 4 so that is $a_{668}=a_{0}=10$...
Kind regards
$\chi$ $\sigma$
FAQ: What is the Value of f(2009) in the Given Recursive Sequence?
How do you find the number of a sequence?
To find the number of a sequence, you can use the formula for the nth term, which is an + b, where a and b represent the first term and the common difference of the sequence, respectively. Plug in the position of the term you want to find into the formula to get the value of that term.
What is the pattern in a sequence?
The pattern in a sequence is the way the numbers are increasing or decreasing from one term to the next. It can be represented by a formula or a rule that describes how to get from one term to the next.
How do you determine if a sequence is arithmetic or geometric?
An arithmetic sequence has a constant difference between each term, while a geometric sequence has a constant ratio between each term. To determine if a sequence is arithmetic or geometric, check if the difference or ratio between consecutive terms is the same. If it is, the sequence is either arithmetic or geometric, respectively.
Can you find the number of a sequence without knowing the formula?
Yes, you can find the number of a sequence without knowing the formula by using the differences between consecutive terms. For an arithmetic sequence, the differences will be constant, so you can just add the difference to the last term to find the next one. For a geometric sequence, the ratios will be constant, so you can multiply the last term by the ratio to find the next one.
How do you find the missing term in a sequence?
To find the missing term in a sequence, you can use the known terms to find the common difference or ratio, and then use that to find the missing term. For an arithmetic sequence, subtract one term from the next to find the difference, and for a geometric sequence, divide one term by the next to find the ratio.
