What is the value of $\gamma-\alpha$ for a given $\cos$ equation?
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, the value of $\gamma-\alpha$ in a cosine equation represents the phase shift of the graph and is related to the horizontal translation of the graph. It is inversely proportional to the period of the function and cannot be greater than the period. It does not affect the amplitude of the function and can take on any real number value, although it is typically limited to a range of $-2\pi$ to $2\pi$.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Assume that $\alpha,\, \beta,\,\gamma$ satisfy $0<\alpha<\beta<\gamma<2\pi$.
If $\cos (x+\alpha)+\cos(x+\beta)+\cos(x+\gamma)=0$ for arbitrary $x\in \Bbb{R}$, evaluate $\gamma-\alpha$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution:
1. greg1313
2. MarkFL
3. lfdahl
4. Opalg
Solution from MarkFL:
Using a sum-to-product identity, we may write the given equation as:
\(\displaystyle \cos\left(\frac{\gamma-\alpha}{2}\right)\cos\left(x+\frac{\gamma+\alpha}{2}\right)=\left(-\frac{1}{2}\right)\cos\left(x+\beta\right)\)
Equating constants yields:
\(\displaystyle \cos\left(\frac{\gamma-\alpha}{2}\right)=-\frac{1}{2}\)
Which implies:
\(\displaystyle \gamma-\alpha=2\left(2k+1\pm\frac{1}{3}\right)\pi\) where $k\in\mathbb{Z}$
Given the constraints, we find:
\(\displaystyle \gamma-\alpha=2\left(2(0)+1-\frac{1}{3}\right)\pi=\frac{4}{3}\pi\)
Alternate solution from Opalg:
$$\begin{aligned} \cos(x+\alpha) + \cos(x+\beta) + \cos(x+\gamma) &= \cos x\cos\alpha - \sin x\sin\alpha + \cos x\cos\beta - \sin x\sin\beta + \cos x\cos\gamma - \sin x\cos\gamma \\ &= \cos x(\cos\alpha + \cos\beta + \cos\gamma) - \sin x(\sin\alpha + \sin\beta + \cos\gamma) \end{aligned}$$ If that is zero for all $x$ then $\cos\alpha + \cos\beta + \cos\gamma = \sin\alpha + \sin\beta + \cos\gamma = 0.$ Then $$1 = \cos^2\beta + \sin^2\beta = (\cos\alpha + \cos\gamma)^2 + ( \sin\alpha + \cos\gamma)^2 = 2 + 2\cos\alpha\cos\gamma + 2\sin\alpha\sin\gamma$$ and so $\cos(\gamma - \alpha) = \cos\alpha\cos\gamma + \sin\alpha\sin\gamma = -\frac12$. Therefore $\gamma - \alpha$ must be $2\pi/3$ or $4\pi/3$. But if $\alpha$, $\beta$ and $\gamma$ are all in the interval $[0,2\pi/3]$ then their sines would all be positive and therefore could not have sum zero. So $\gamma - \alpha = 4\pi/3$.
FAQ: What is the value of $\gamma-\alpha$ for a given $\cos$ equation?
What is the significance of the value of $\gamma-\alpha$ in a cosine equation?
The value of $\gamma-\alpha$ in a cosine equation represents the phase shift of the graph. It indicates the horizontal translation of the graph from its original position. A positive value shifts the graph to the right, while a negative value shifts it to the left.
How is $\gamma-\alpha$ related to the period of the cosine function?
The value of $\gamma-\alpha$ is inversely proportional to the period of the cosine function. This means that as the value of $\gamma-\alpha$ increases, the period of the function decreases, and vice versa.
Can the value of $\gamma-\alpha$ be greater than the period of the cosine function?
No, the value of $\gamma-\alpha$ can never be greater than the period of the cosine function. The period of a cosine function is always positive, while the value of $\gamma-\alpha$ can be positive or negative.
How does changing the value of $\gamma-\alpha$ affect the amplitude of the cosine function?
The value of $\gamma-\alpha$ does not affect the amplitude of the cosine function. The amplitude of a cosine function is determined by the coefficient in front of the cosine term. The value of $\gamma-\alpha$ only affects the phase shift and period of the function.
Is there a specific range of values for $\gamma-\alpha$ in a cosine equation?
The value of $\gamma-\alpha$ can take on any real number value in a cosine equation. However, it is typically limited to a range of $-2\pi$ to $2\pi$ in order to ensure that the graph remains periodic and does not overlap with previous or future periods.
