What is the value of the expression given these equations?
In summary, we are given two equations, $\dfrac {x}{m}+\dfrac{y}{n} +\dfrac {z}{p}=1$ and $\dfrac {m}{x}+\dfrac{n}{y} +\dfrac {p}{z}=0$, and we are asked to find the value of $\dfrac {x^2}{m^2}+\dfrac{y^2}{n^2} +\dfrac {z^2}{p^2}$ when the value of $\dfrac {m^2}{x^2}+\dfrac{n^2}{y^2} +\dfrac {p^2}{z^2}$
Albert1
1,221
given :
find:
$\dfrac {x^2}{m^2}+\dfrac{y^2}{n^2} +\dfrac {z^2}{p^2}=?$
Mathematics news on Phys.org
Re: find value
Albert said:
given :
find:
Hello.
[tex]\dfrac {x^2}{m^2}+\dfrac{y^2}{n^2} +\dfrac {z^2}{p^2}=1[/tex]
1º)
[tex]\dfrac {m}{x}+\dfrac{n}{y} +\dfrac {p}{z}=0[/tex]
[tex]myz+nxz+pxy=0[/tex]
[tex](mnp)(myz+nxz+pxy)
=0[/tex]
[tex]mnpmyz+mnpnxz+mnppxy=0[/tex](*)
2º)
[tex]\dfrac {x}{m}+\dfrac{y}{n} +\dfrac {z}{p}=1[/tex]
[tex]xnp+myp+mnz=mnp[/tex]
[tex](xnp+myp+mnz)^2=m^2n^2p^2[/tex]
[tex]x^2n^2p^2+m^2y^2p^2+m^2n^2z^2+[/tex]
[tex]+2xnpmyp+2xnpmnz+2mypmnz=m^2n^2p^2[/tex]
For (*):
[tex]2xnpmyp+2xnpmnz+2mypmnz=0[/tex]
Then:
[tex]x^2n^2p^2+m^2y^2p^2+m^2n^2z^2=m^2n^2p^2[/tex]
[tex]\dfrac{x^2n^2p^2+m^2y^2p^2+m^2n^2z^2}{m^2n^2p^2}=1[/tex]
Regards.
Hello, Albert!
[tex]\text{Given: }\:\dfrac {x}{m}+\dfrac{y}{n} +\dfrac {z}{p}=1[/tex]
. . . . . . . [tex]\dfrac {m}{x}+\dfrac{n}{y} +\dfrac {p}{z}=0[/tex]
[tex]\text{Find: }\:\dfrac {x^2}{m^2}+\dfrac{y^2}{n^2} +\dfrac {z^2}{p^2}[/tex]
[tex]\text{Let: }\:a\,=\,\frac{x}{m},\;\;b \,=\, \frac{y}{n},\;\;c \,=\, \frac{z}{p}[/tex]
[tex]\text{We have: }\:\begin{Bmatrix}a+b+c &=& 1 & [1] \\ \frac{1}{a}+\frac{1}{b} + \frac{1}{c} &=& 0 & [2] \end{Bmatrix}[/tex]
[tex]\text{And we want: }\:a^2+b^2+c^2.[/tex][tex]\text{From [2]: }\:\frac{ab+bc+ac}{abc} \:=\:0 \quad\Rightarrow\quad ab + bc + ac \:=\:0[/tex]
[tex]\text{Square [1]: }\: (a+b+c)^2 \:=\:1 ^2[/tex]
. . [tex]a^2+2ab+2ac+b^2+2bc+c^2 \:=\:1[/tex]
. . [tex]a^2+b^2+c^2 + 2\underbrace{(ab + bc + ac)}_{\text{This is }0} \:=\:1[/tex]
[tex]\text{Therefore: }\:a^2+b^2+c^2 \:=\:1[/tex]
Albert said:
given :
find:
now the following value can be found (is it a fixed number)?
$\dfrac {m^2}{x^2}+\dfrac{n^2}{y^2} +\dfrac {p^2}{z^2}=?$
To find the value of this expression, we can use the given equations to solve for the values of x, y, and z in terms of m, n, and p. From the first equation, we can rearrange to get x = m(1 - y/n - z/p). Substituting this into the second equation, we get m(1 - y/n - z/p)^2/m + n/y + p/z = 0. Simplifying, we get 1 - y/n - z/p = 0. This means that y/n + z/p = 1. Substituting this into the first equation, we get x/m + 1 = 1, which means x = 0. Similarly, we can solve for y and z to get y = 0 and z = 0.
Substituting these values into the expression we are trying to find, we get (0)^2/(m^2) + (0)^2/(n^2) + (0)^2/(p^2) = 0. Therefore, the value of the expression is 0.
FAQ: What is the value of the expression given these equations?
What is an expression?
An expression is a mathematical statement that uses numbers, variables, and mathematical symbols to represent a value.
How do I find the value of an expression?
To find the value of an expression, you need to replace the variables with their given values and then use the correct order of operations to simplify the expression.
What is the order of operations?
The order of operations, also known as PEMDAS, is a set of rules that dictate the sequence in which operations should be performed in a mathematical expression. It stands for Parentheses, Exponents, Multiplication and Division (from left to right), and Addition and Subtraction (from left to right).
Can an expression have more than one solution?
Yes, an expression can have more than one solution. This usually occurs when the expression contains variables and the given values can result in different solutions.
Why is it important to simplify an expression?
Simplifying an expression helps to make it easier to understand and work with. It also allows you to find the true value of the expression without any unnecessary steps or confusion.
