What is the value of the summation of (2^n+1)/3^n?
In summary, the conversation discusses finding the value of the summation of 2n+1/3n from n=1 to infinity. The speaker suggests changing the expression to 2*(2/3)n to use as a geometric series and applies the formula "a/(1-r) = sum" where a is the first term and r is the ratio. The answer is calculated to be 4, but a suggestion is made to subtract the n=0 term to account for the series starting at 1 rather than 0. The conversation also references the famous geometric series test for starting at 0 and provides a formula for calculating the sum when r<1 and n_0\geq0.
IntegrateMe
217
So the question asks: What is the value of the "summation of" 2n+1/3n from "n=1 to infinity."
I changed 2n+1/3n into 2*(2/3)n so i could use it as a geometric series.
So now i just use the rule "a/(1-r) = sum" where a = first term and r = ratio i get 2/(1-(2/3)) which = 6. The answer is 4, any suggestions?
Isn't your first term 2/3?
Oh wait, so the first term is 4/3 so i get (4/3)/[1-(2/3)] = 4. Thank you guys!
VeeEight said:
Your series is going from 1 to infinite. The famous geometric series test is used when the sum starts at 0. So you must subtract the n = 0 term
See here: http://en.wikipedia.org/wiki/Geometric_series#Formula
The [itex]a[/itex] in the numerator takes care of that.
[tex]\sum_{n=n_0}^\infty r^n=\frac{r^{n_0}}{1-r}=\frac{a}{1-r}[/tex]
(When [itex]r<1[/itex] and [itex]n_0\geq0[/itex] of course)
FAQ: What is the value of the summation of (2^n+1)/3^n?
The value of the summation of (2^n+1)/3^n is an infinite geometric series with a common ratio of 2/3. This means that the value of the sum will approach a specific number as n approaches infinity.
How do you find the value of an infinite geometric series?
To find the value of an infinite geometric series, you can use the formula S = a / (1 - r), where S is the sum, a is the first term, and r is the common ratio. In the case of (2^n+1)/3^n, a = 1 and r = 2/3. Plugging these values into the formula, we get S = 1 / (1 - 2/3) = 3.
What is the significance of the common ratio in an infinite geometric series?
The common ratio in an infinite geometric series represents the rate of change between consecutive terms. In the case of (2^n+1)/3^n, the common ratio of 2/3 means that each term is 2/3 times the previous term. This ratio helps determine whether the series will converge or diverge.
Can the value of an infinite geometric series ever be negative?
Yes, the value of an infinite geometric series can be negative. This can happen when the common ratio is negative and the absolute value of the ratio is less than 1. In this case, the series will alternate between positive and negative values, resulting in a negative overall sum.
Is there a specific method to determine if an infinite geometric series will converge or diverge?
Yes, there is a specific method called the Ratio Test that can be used to determine if an infinite geometric series will converge or diverge. The test states that if the absolute value of the common ratio is less than 1, the series will converge, and if it is greater than 1, the series will diverge. If the absolute value is exactly 1, the test is inconclusive and other methods must be used to determine convergence or divergence.
