What is the value of x in the equation 7^(x) + 3^(x) = (2.1)^(-1)?
  • MHB
  • Thread starter mathdad
In summary, to solve for x in the equation 7^(x) + 3^(x) = (2.1)^(-1), we can use the fact that (2.1)^(-1) is equal to 1/7 + 1/3. Then, by equating the exponents on the left side of the equation, we get the solution x = -1.
mathdad
1,283
Solve for x:
My Work:
Note: I understand (2.1)^(-1) as the decimal number 2.1 raised to the negative 1, which can be expressed as 1/(2.1).
ln[7^x] + ln[3^x] = ln[1/(2.1)]
xln7 + xln3 = -0.741937
x(ln7 + ln3) = -0.741937
x = 1/[(-0.741937)(ln7 + ln3)]
Use a calculator to find an approximate x value.
x = -0.442704
Correct?
Mathematics news on Phys.org
RTCNTC said:
Solve for x:
My Work:
x = -0.442704
Correct?
Not correct. Look at those two lines in red. What is wrong there?
A better approach would be to start from the fact that \(\displaystyle 2.1^{-1} = \frac1{2.1} = \frac{10}{21}.\) Notice that $10 = 3+7$ and $21 = 3\times7$.
I am wrong. I get it. Can you provide the needed steps for me to solve this exponential equation?
You see the LHS of the equation is the sum of 7 and 3 raised to the same power. Using the suggestion posted by Opalg, can you express 10/21 as the sum of 7 and 3 raised to the same power?
I do not understand.
Okay, we are originally given:
\(\displaystyle 7^x+3^x=2.1^{-1}\)
We can write this as:
\(\displaystyle 7^x+3^x=\frac{10}{21}=\frac{3+7}{7\cdot3}=\frac{1}{7}+\frac{1}{3}=7^{-1}+3^{-1}\)
And so what value must $x$ have?
The value of x = (1/7) + (1/3), right?
No, we have:
\(\displaystyle 7^x+3^x=7^{-1}+3^{-1}\)
Therefore, the exponents must be equal, which means:
\(\displaystyle x=-1\)
Thanks.
FAQ: What is the value of x in the equation 7^(x) + 3^(x) = (2.1)^(-1)?
The value of x in this equation cannot be determined without more information. It is a transcendental equation, meaning it cannot be solved algebraically. It would require numerical methods to approximate a solution.
How many possible values of x are there in the equation 7^(x) + 3^(x) = (2.1)^(-1)?
As mentioned before, the equation is transcendental and cannot be solved algebraically. Therefore, there are an infinite number of possible values for x.
Can the equation 7^(x) + 3^(x) = (2.1)^(-1) be solved using logarithms?
No, logarithms cannot be used to solve this equation as it does not have a single variable in the exponent.
Is there a way to approximate a solution for x in the equation 7^(x) + 3^(x) = (2.1)^(-1)?
Yes, numerical methods such as Newton's method or the bisection method can be used to approximate a solution for x. However, these methods may not give an exact solution and may require multiple iterations to get a close approximation.
Can x be a complex number in the equation 7^(x) + 3^(x) = (2.1)^(-1)?
Yes, x can be a complex number in this equation. Since the equation is transcendental, it can have real and complex solutions.
