AstroMath
- 24
What is the velocity of the photon through the fourth dimension x4?
Photons are real, physical entities.
The fourth dimension is a real, physical entity.
Therefore, photons must have a relationship with the fourth dimension. They must have some velocity relative to it.
Do you agree with the following:
Einstein's GR taught us that dimensions could bend, curve, and move and so does dx4/dt=ic.
Does the above logic make sense to you?
What, in your opinion, is the velocity of the photon through the fourth dimension x4?
(HINT:
Consider the equation x4=ict.
When t=1, what is x4? When t=2, what is x4? When t=3, what is x4? What happens to x4 as the seconds on your watch tick by? In three seconds, how far has x4 moved? 3*ic meters!
- Maxwell/Einstein teach that light has the velocity c through the three spatial dimensions.
- Relativity teaches us that the velocity of every object is c through the four-dimensional spacetime manifold.
- If a photon has a velocity other than zero relative to the fourth dimension, then either #1 or #2 above would no longer be true.
- As #1 and #2 must always be true, a photon must remain stationary relative to the fourth dimension.
- As a photon is stationary relative to the fourth dimension, it tracks and traces x4's movement. The fourth dimension is moving at c relative to the three spatial dimensions.
(HINT:
