What is the volume of a pyramid with given side lengths?
  • MHB
  • Thread starter Ackbach
In summary, the formula for finding the volume of a pyramid with given side lengths is V = (1/3) * base area * height. The volume cannot be negative and is typically measured in cubic units. To find the height, the formula can be rearranged to solve for height. However, the volume cannot be determined if only the side lengths are given, as the height is also needed.
Ackbach
MHB
4,155
93
Here is this week's POTW:
Determine the volume of a tetrahedron $ABCD$ if
$$\overline{AB}=\overline{AC}=\overline{AD}=5$$
and
$$\overline{BC}=3, \; \overline{CD}=4,\;\overline{DB}=5.$$
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to castor28 for his correct solution to this week's POTW, which was Problem 307 in the MAA Challenges. His solution follows:
[sp]By the converse of Pythagoras’ theorem, the triangle $BCD$ is a right triangle with hypotenuse $DB$; the area of that triangle is equal to 6.
From $A$, we draw the perpendicular to the plane $BCD$, intersecting the plane at $O$; $AO$ is the altitude of the pyramid relative to the base $BCD$.
The right triangles $AOB$, $AOC$, and $AOD$ are congruent, since they share the side $AO$ and their hypotenuses are equal. This shows that $BO=CO=DO$, and $O$ is the center of the circumcircle of the triangle $BCD$. As that triangle is a right triangle, $O$ is the midpoint of the hypotenuse $DB$, and $BO=\dfrac52$. This gives:
$$AO=\sqrt{AB^2-BO^2}=\frac{5\sqrt3}{2}$$
and the volume of the pyramid is equal to:
$$\frac13\times6\times\frac{5\sqrt3}{2}=5\sqrt3$$[/sp]
FAQ: What is the volume of a pyramid with given side lengths?
What is the formula for finding the volume of a pyramid with given side lengths?
The formula for finding the volume of a pyramid with given side lengths is V = (1/3) * base area * height. The base area can be calculated by multiplying the length and width of the base together.
Can the volume of a pyramid be negative?
No, the volume of a pyramid cannot be negative. Volume is a measure of space and therefore cannot have a negative value.
What unit of measurement is typically used for the volume of a pyramid?
The volume of a pyramid is typically measured in cubic units, such as cubic inches or cubic centimeters.
How do you find the height of a pyramid with given side lengths and volume?
To find the height of a pyramid with given side lengths and volume, rearrange the formula V = (1/3) * base area * height to solve for height. The formula would be height = (3 * V) / base area.
Can the volume of a pyramid be determined if only the side lengths are given?
No, the volume of a pyramid cannot be determined if only the side lengths are given. The height is also needed in order to calculate the volume using the formula V = (1/3) * base area * height.
