What is the volume of the set of points within 1 unit of a solid box?
  • MHB
  • Thread starter Chris L T521
In summary, volume is defined as the amount of space an object occupies. To calculate the volume of a solid box, you multiply the length, width, and height. "Within 1 unit" refers to points being measured within a distance of 1 unit from the surface of the box. The volume of a solid box is always a positive value and cannot be negative. The volume of a set of points within 1 unit of a solid box is smaller than the volume of the box itself because it only includes a portion of the space occupied by the box.
Chris L T521
MHB
915
Thanks again to those who participated in last week's POTW! Here's this week's problem!
Problem: Let $B$ be a solid box with length $L$, width $W$, and height $H$. Let $S$ be the set of all points that are a distance at most $1$ from some point of $B$. Express the volume of $S$ in terms of $L$, $W$, and $H$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
This week's problem was correctly answered by magneto, MarkFL, Opalg, and Pranav. You can find magneto's solution below.
[sp]We will construct the "meta-box" and add the volume.
(a) The volume of the box is $LWH$.
(b) We can extend each of the surface of the box by 1. This creates two blocks of boxes of volume $LW$, $LH$, and $WH$ each. So the total volume would be $2(LW+LH+WH)$.
(c) There are 8 corners each is of $\frac{1}{8}$ of a sphere of radius $1$, so the total volume would be $\frac{4}{3} \pi$.
(d) There are 12 quarter-cylinder, 4 for each dimension of the box. These cylinder's have height of the side of the box, and radius of $1$,
so the total volume is given by $\pi(L+W+H)$.
Therefore, the total volume is $LWH + 2(LW+LH+WH) + \pi (\frac{4}{3} + L + W + H)$.[/sp]
FAQ: What is the volume of the set of points within 1 unit of a solid box?
What is the definition of volume?
The volume of an object is the amount of space that it occupies.
How is the volume of a solid box calculated?
The volume of a solid box is calculated by multiplying the length, width, and height of the box. The formula is V = lwh.
What is meant by "within 1 unit" in regards to volume?
"Within 1 unit" means that the points being measured are within a distance of 1 unit from the surface of the solid box in all directions.
Can the volume of a solid box be negative?
No, the volume of a solid box is always a positive value. It represents the amount of space occupied by the object.
How is the volume of a set of points within 1 unit of a solid box different from the volume of the solid box itself?
The volume of a set of points within 1 unit of a solid box is a smaller value than the volume of the solid box itself. This is because the set of points only includes the space within 1 unit of the box, while the volume of the box includes all of the space occupied by the box.
