What is the volume of the shipping box?
  • MHB
  • Thread starter mathdad
  • Tags
    Box Volume
In summary: I'm sure that MarkFL is a very knowledgeable person and he does a great job in answering the question.
mathdad
1,283
A shipping box is filled with pastry boxes. Each pastry box measures 1 cubic foot. The shipping box is 3 feet high. The bottom layer of the shipping box can fit 6 pastry boxes. What is the volume of the shipping box?
Do I simply multiply 1 by 3 by 6 to get 18 cubic feet?
Mathematics news on Phys.org
That would be assuming the pastry boxes are cubical. If we don't make that assumption, then all we know is:
\(\displaystyle w_P\ell_P h_P=1\)
Now we also know:
\(\displaystyle w_S\ell_S=6w_P\ell_P=\frac{6}{h_P}\)
And so the volume of the shipping box is:
\(\displaystyle V_S=6\frac{h_S}{h_P}=\frac{18}{h_P}\)
So, we see that the volume of the shipping box depends on the height of the pastry boxes, in an inverse variation. :D
Now we also know:
I hope to someday understand math at your level.
I'm sure that MarkFL is proficient in mathematics at a very high level. But the mathematics he used on this problem is about eighth grade algebra.
You are right but word problems are a BIG PROBLEM for me at any grade level after 6th grade. There is no need for the put down.
FAQ: What is the volume of the shipping box?
What is the formula for calculating the volume of a shipping box?
The formula for calculating the volume of a shipping box is length x width x height. This will give you the total amount of space inside the box, measured in cubic units.
How do I measure the dimensions of a shipping box?
To measure the dimensions of a shipping box, use a ruler or measuring tape to find the length, width, and height of the box. Make sure to measure from the inside of the box for accurate dimensions.
Is the volume of a shipping box the same as its capacity?
Yes, the volume and capacity of a shipping box are the same. Both refer to the amount of space inside the box that can be filled with items or materials.
Can I use any unit of measurement for the dimensions of a shipping box?
Yes, you can use any unit of measurement for the dimensions of a shipping box as long as they are all the same. For example, if you measure the length in inches, then the width and height should also be measured in inches.
How can I use the volume of a shipping box to determine shipping costs?
You can use the volume of a shipping box to determine shipping costs by multiplying it by the shipping rate charged per cubic unit. This will give you the total cost for shipping the box based on its size.
