What is the Vrms, in m/s, for helium atoms at 4.8 K?
In summary, the Vrms for helium atoms at 4.8 K, close to the point of liquefaction, is √(0.9559) = 0.9774 meters per second. This is calculated using the equation Vrms= √(3RT)/(M), with R=3.1845 J/mol*K, T=4.8 K, and M=0.004003 kg/mol.
Ashley Cornwell
What is the Vrms, in meters per second, for helium atoms at 4.8 K? (which is close to the point of liquefaction)
Vrms= √(3RT)/(M)
R=3.145
T= I think its 4.15 Kelvin? based on the point of liquefaction of helium being -269°C
-unsure about the temperature
M= I think its 0.004003 Kg based on the molar mass of helium
Vrms= Sqrt (3*3.1845*4.15)/(0.004003)
Any help would be greatly appreciated, I've tried this a million ways and can't seem to figure it out,
Thank You!
Welcome to PF!
You don't have the correct value of R if you are using SI units.
They want you to use 4.8 K for T.
Otherwise, your method looks correct.:smile:
TSny said:
Welcome to PF!
Thank You!
Related to What is the Vrms, in m/s, for helium atoms at 4.8 K?
1. What is Vrms?
Vrms stands for "root-mean-square velocity," which is the measure of the average speed of particles in a gas.
2. How is Vrms calculated?
Vrms is calculated using the equation Vrms = √(3RT/M), where R is the gas constant, T is the temperature, and M is the molar mass of the gas.
3. What is the unit for Vrms?
The unit for Vrms is meters per second (m/s).
4. What is the Vrms for helium atoms at 4.8 K?
The Vrms for helium atoms at 4.8 K can be calculated using the molar mass of helium (4.0026 g/mol) and the gas constant (8.314 J/mol·K). Plugging these values into the Vrms equation, we get Vrms = √(3 * 8.314 J/mol·K * 4.8 K / 4.0026 g/mol) = 128.53 m/s.
5. How does the temperature affect Vrms?
As the temperature of a gas increases, the Vrms also increases. This is because higher temperatures mean that the gas particles have more kinetic energy, leading to faster average speeds and a higher Vrms.
35K
9K
