What is the work done by a horse pulling a cart?
The discussion focuses on calculating the work done by a horse pulling a cart, with participants comparing their solutions. The author initially provided a value of 332,190 Joules, while another participant calculated 355,940 Joules, attributing the difference to conversion issues and a miscalculation of the weight from 45 lb to 42 lb. After correcting for the weight, the recalculated work done is approximately 332,210 Joules, highlighting a minor discrepancy of 0.04%. The conversation emphasizes the importance of accurate unit conversions and the potential for small errors to significantly impact results. Overall, the discussion underscores the need for careful attention to detail in physics calculations.
walking
The answers for author's solution differ slightly from mine when I convert his answers to SI. I think this is only a conversion issue as the differences are small but I wanted to confirm if my solution is correct:
d=rt (distance = rate x time) so (12 min)(6.2mi/h)(60s/1min)(0.3048m/s)(0.6816mi/h). Then $$W=(F\cos \theta)d=(45lb\cos 27)d$$ etc. I end up getting 355940J wjereas author gets 332190J (he doesn't give answer in J since he works with feet, but after converting it to J using accurate conversion rates this is what I got).
I got 244,921 lb*ft which converts to 332,068 Joules. My answer differs from the author's by 0.04%. Yours differs by 7.1%. It looks like it's more accurate to work with feet and do one final conversion in the end.
What did you get for part (b)?
It doesn't say 45 lb, it says 42 lb.
356 or 332 is too far off for conversion accuracy
Your
has the wrong dimension.
What is (0.3048 m/s)(0.6816 mph) ?
I get 332.1904 kW ##\qquad##:smile:
Note that providing more than two digits is questionable: it suggests more accuracy than actually justified
And the discrepancy between 45 and 42 is 7.1%. I didn't notice the mistaken input.
Right, so I made the mistake of using 45lb instead of 42. When I use 42 I get $$(42lb\cos 27)(12min)(6.2mi/h)\left( \frac{10^{-5}N}{2.248\times 10^{-6}lb}\right)\left(\frac{60s}{1min}\right)\left(\frac{0.3048m/s}{0.6818mi/h}\right)=332210=3.32\times 10^5 J$$
  • · Replies 16 ·
