I What is this form of concavity called?
  • I
  • Thread starter Thread starter pitaly
    Form
The discussion centers on identifying a specific form of concavity related to a differentiable function defined on a subset of real numbers. The concept is defined through a gradient map and involves a vector that influences the relationship between function values at two points. The standard form of concavity is established when this vector is set to zero. While the specific generalization in question is not readily identifiable, the existence of numerous concavity generalizations complicates the search for equivalence. Understanding this form of concavity may require further exploration of existing literature on the topic.
pitaly
TL;DR Summary
I'm working on a model which produces a form of concavity which I'm not familiar with. Does anyone know what this form is called and if it has been studied before?
The definition in its differentiable version reads:
Let ##X\subset \mathbb{R}^{n}##. A differentiable function ##f##, defined on ##X##, with a gradient map ##\nabla f## is called ??-concave, if there exists a vector ##\beta \in \mathbb{R}_{++}^{n}##, such that the following holds for all ##x,y\in X:##
##f\left( y\right) -f\left( x\right) -\nabla f\left( x\right) \cdot \left(y-x\right) \leq \beta \cdot \left( y-x\right)##
The standard form of concvaity is obtained by setting ##\beta=0##
Mathematics news on Phys.org
I couldn't find your specific generalization, but there are so many generalizations of the concept, that it is hard to tell whether yours is among them or possibly equivalent to any.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
