What is torque in electric motors?
In summary, torque is a measure of the rotational force in electric motors, and it is directly related to power. The strength of the magnetic field, number of turns in the coil, current, and armature shape and size all affect the torque of an electric motor. Torque is typically measured in Newton-meters or pound-feet using a torque sensor or dynamometer. It is important in electric motors as it determines the motor's ability to perform work.
Sunturday
What is torque in electric motors? And why is it largest when a single armature is horizontal to the field?
Torque is the power of the motor divided by the RPM. When the load on the motor increases, it becomes difficult to rotate the load at the same RPM as the lesser load before. More torque is required and the RPM decreases.
Not the best of explanations, but i hope you got an idea.
Don't quite remember the second part. I'll check if I can find anything.
Related to What is torque in electric motors?
Torque is a measure of the rotational force or the ability of a force to cause an object to rotate. In electric motors, torque is the force that causes the motor's armature to rotate, generating power.
How is torque related to power in electric motors?
Torque and power are directly related in electric motors. Torque is the force that causes rotation, while power is the rate at which work is done. In simple terms, higher torque results in higher power output from the motor.
What factors affect the torque of an electric motor?
The torque of an electric motor is affected by various factors such as the strength of the magnetic field, the number of turns in the coil, the current flowing through the coil, and the shape and size of the motor's armature.
How is torque measured in electric motors?
Torque is measured in Newton-meters (Nm) or pound-feet (lb-ft) in electric motors. This is typically done using a torque sensor or a dynamometer, which measures the force applied to the motor's shaft and the distance from the center of rotation.
Why is torque important in electric motors?
Torque is crucial in electric motors as it determines the motor's ability to perform work. Higher torque allows the motor to overcome resistance and produce more power, while lower torque may result in the motor stalling or not being able to complete its intended task.
  • Mechanical Engineering
