What is Variation of Parameters ?
In summary, the conversation discusses the concept of "Variation of Parameters," which is a method used to solve differential equations by using a known solution and one equation to find a second equation. The conversation also includes a specific example problem and the process for solving it using this method. Additionally, there is some discussion about the difficulty of understanding this method and the use of matrices in integration.
alpha754293
29
What is "Variation of Parameters"?
None. General.
I don't know. :( ?
I am taking a class right now on engineering analysis (which I am finding it to be more like partial differential equations mixed with boundary value problems on steroids) and the way that my professor is explaining stuff to us doesn't make a lot of sense to me and I've tried asking him and it doesn't really seem to be helping.
I've also tried looking it up on the internet as well, and they all pretty much say the same thing, which doesn't really help me understand it either.
So...what IS "variation of parameter"?
Are they really good examples that show how it is used and how to solve problems with it?
We don't have TA's or anything like that at my school, and because it's considered to be a graduate level class, we also don't have any tutors for it either. :(
We were told that we had to use this method in the one of the programs that was posted on here: https://www.physicsforums.com/showthread.php?t=265432&highlight=cauchy-euler
And I didn't understand what it meant by "using variation of parameters' method.
So any help that can explain what my prof is talking about would be GREATLY appreciated!
"Wikipedia"[/URL] has the basic proof I was going to type out.
It is just to basically apply two formulas and find y.
In the example problem that I have linked above, how would I go about using it to solve it?
(I understand that it might be too much to ask for a full solution, but it would definitely help for me to try and understand it.)
I read it on Wikipedia and a few other places and it hasn't doesn't help me understand it any better. :(
The problem given is "[itex]x^2y"+ axy+ by= 0[/itex]". We are given that [itex]y_1= x^m [/itex] is a solution and are asked to use "variation of parameters" to find another solution.
Try a solution of the form [itex]y(x)= x^mu(x)[/itex] for some unknown function u(x). Then [itex]y'= mx^{m-1}u+ x^mu'[/itex] and [itex]y"= m(m-1)x^{m-2}u+ 2mx^{m-1}u'+ x^mu"[/itex]. Putting those into the equation gives
[tex]m(m-1)x^mu+ 2mx^{m+1}u'+ x^{m+2}u"+ amx^mu+ ax^{m+1}u'+ bx^mu[/tex]
[tex]= x^m\left[m(m-1)+am+ b\right]u+ x^{m+1}(xu"+ (2m+ a)u')= 0[/itex]
Because were are told that [itex]x^m[/itex] satisfies the equation, we must have [itex]m(m-1)+ am+ b= 0[/itex]. From that, we can divide both sides of the equation by [itex]x^m[/itex] and get
[tex]xu"+ (2m+ a)u'= 0[/itex]
Let v= u' and that becomes the easy, separable, first order equation xv'+ (2m+a)v= 0 or
dv/v= (2m+a)dx/x.
dv/v= (2m+a)dx/x.
okay...so if I understand this correctly -- variation of parameters uses one equation and one known solution to find a second equation.
and then using the first equation and the new equation that we just found, we apply that to the original problem in order to try to solve it?
Do I have that right?
(I'm trying to read LaTeX, but it doesn't render properly in my brain. (I'd wished that people would just write the equations in like Word or something and then save it as a PNG or GIF or something), but I suppose that would be to difficult, and not everybody uses word.)
I think HallsofIvy did reduction of order where you know one solution,y1, and use the fact that the other solution is y=vy1
But this is the basic method of how to solve a DE using the method of variation of paramters.
Solve: y''+y= sinx/cosx
using the auxiliary equation (since the DE has constant coeffcients), we get
m2+1=0 => [itex]0 \pm i[/itex] ( this implies a solution of Acosx+Bsinx)
So we let y1=sinx and y2=cosx
We now find the wronskian of y1 and y2, W(y1,y2) which is given by
|sinx cosx|
|cosx -sinx|
thus W(y1,y2)= -sin2x-cos2x=-1.
and the answer we want is y=v1y1+v2y2
Where
[tex]v_1 = \int \frac{-y_2 r}{W(y_1,y_2)}dx[/tex]
and
[tex]v_2= \int \frac{y_1 r}{W(y_1,y_2)} dx[/tex]
(In this example r=sinx/cosx i.e. the RHS of the DE)
Working it out now
[tex]v_1= \int \frac{-cosx*\frac{sinx}{cosx}}{-1}dx= \int sinx dx=-cosx+c_1[/tex]
[tex]v_2= \int \frac{sinx*\frac{sinx}{cosx}}{-1}dx= \int \frac{cos^2x-1}{cosx}dx=\int (cosx-secx)dx=sinx-ln(sex+tanx)+c_2[/tex]
Now putting it back into out solution of y=y1v1+y2v2, we get
y=sinx(-cosx+c1) +cosx(sinx-ln(secx+tanx +c2)
y= c1sinx+c2sinx -sinxcosx-cosxln(secx+tanx)
(Noting that y is always the sum of yc and yp where yc=c1sinx+c2cosx)
Oh...
I think I get it now. sorta. So you have to start with like some kind of either given or assumed form of the solution for it to work.
I am also guessing that you kinda have to do it this way because there aren't too many options in solving those problems?
(Seems like it's a lot of work to get an answer, but I should really be less surprised considering that the class that I'm supposed to be learning this stuff in is basically PDE with initial and boundary conditions (I don't know if you would consider that PDE/BVP or just BVPs), but in either case, it's that...on steroids. And then some.)
Like I said, I've tired to do some research to solve the problem that was given to us and the prof isn't very helpful in explaining it. Sadly, the one good math prof that I like is a semi-retired adjunct professor and he's pretty much on and off campus at random.
Next dumb question: How do you integrate a Wronskian?
FAQ: What is Variation of Parameters ?
1. What is Variation of Parameters?
Variation of Parameters is a method used to find a particular solution to a non-homogeneous linear differential equation. It involves finding a set of functions, known as the variation of parameters, that can be used to represent the unknown coefficients in the particular solution.
2. How is Variation of Parameters different from other methods of solving differential equations?
Variation of Parameters differs from other methods, such as the method of undetermined coefficients or the method of integrating factors, because it allows for a wider range of functions to be used in the particular solution. This makes it more versatile and applicable to a broader range of differential equations.
3. When is Variation of Parameters typically used?
Variation of Parameters is typically used when the non-homogeneous term in a differential equation is a polynomial, trigonometric function, or exponential function. It is also useful when the coefficients in the equation are not constant.
4. How does Variation of Parameters work?
Variation of Parameters involves finding a set of functions that satisfy both the original differential equation and a set of additional conditions. These functions are then substituted into the general solution of the homogeneous equation, resulting in a particular solution that satisfies the non-homogeneous equation.
5. What are the main benefits of using Variation of Parameters?
One of the main benefits of using Variation of Parameters is that it allows for a more general solution to be found for non-homogeneous linear differential equations. It also does not require any additional knowledge about the non-homogeneous term, making it a more straightforward method to use in certain cases.
