What is zero error of a measuring instrument ?
In summary: It is possible that a three-dimensional correction could be applied, but I'm not sure how that would work.In summary, zero error of a measuring instrument is the systematic error in a measurement due to non-uniform or wrongly marked graduation due to which a measurement may be less or greater than actual measurement.
SSG-E
60
I cannot come up with a correct definition and explanation for zero error.
In case of vernier callipers:
actual reading = main scale + vernier scale − (zero error).
Is this correct?
"The systematic error in a measuring instrument due to non-uniform or wrongly marked graduation due to which a measurement may be less or greater than actual measurement is called zero error of the measuring instrument".
Another one:
The measuring instruments are combination of two or more scales. The accuracy of these scales depend on each other. If these scales are not on zero level with respect to each other then zero error occurs. So we can say that:
"Th error which occurs in a measuring instrument due to non-levelling of scales on zero point is called zero error.
I have no idea of the definition of zero error, but I have a couple of examples of zero discrepancies on my instruments.
I have several moving coil galvanometers, where magnetic torque is balanced by torque from a spring or taut wire. All have an adjustment to the tension in the spring or wire, so that you can get a reading of zero when no current flows. If you haven't checked for a while, you'd get an error.
I have a micrometer that does not read zero when the jaws are closed, so I subtract the zero reading from any reading I take.
Thinking about it now, there is also a barometer and a dial thermometer with such adjustment.
Rulers may have a zero error resulting from the way they are used. You won't do it, but at school one had to remind people not to measure from the end of the ruler, but from the start of the scale.
Rulers with no guard could get damaged and give a zero error.
My steel tape measue has an end riveted through a slot, so that the end can move by the thickness of the metal end. If you measure externally, you pull the end out and measure from the inside face, or for internal measurement, push the end in and measure from the outside face. Without this there could be a small zero error up to the thickness of the endpiece.
Looking at your definitions, the first one sounds ok, except that I would not call non-uniform graduation a zero error. A zero error shifts the whole scale up or down and can be corrected, as you indicate, by subtracting the error. That would not work for a non-uniform scale. For galvanometers we had calibration charts to correct for non-uniformity, but the zero error needed to be adjusted out.
The second one simply doesn't remind me of instruments I know. If such an instrument did rely on the alignment of two scales, then the discrepancy between the zero points would qualify and could be corrected for.
I suppose you could say that of my micrometer, but I don't regard the linear and rotary parts as two scales. They make one scale, with the crude linear part simply keeping track of the number of turns of the rotary part.
As for an explanation. If an instrument doesn't read zero when measuring zero, then that error should be present for all other readings. If the scale is linear, the error can be corrected by simply subtracting the zero error. For a non-linear scale, it could be more difficult.
Likes SSG-E
Related to What is zero error of a measuring instrument ?
1. What is zero error of a measuring instrument?
The zero error of a measuring instrument refers to the deviation from the true value when the instrument is set to zero. It can be positive or negative, depending on whether the instrument is reading above or below the true zero point.
2. How does zero error affect measurements?
Zero error can significantly affect the accuracy of measurements. If the instrument has a positive zero error, it will consistently give readings that are higher than the true value, and vice versa for negative zero error. This can lead to incorrect conclusions and decisions based on the measurements.
3. What causes zero error in measuring instruments?
There are several factors that can cause zero error in measuring instruments. It could be due to manufacturing defects, wear and tear, or incorrect calibration. Environmental factors such as temperature and humidity can also contribute to zero error.
4. How can zero error be corrected?
To correct zero error, the instrument needs to be recalibrated. This involves adjusting the instrument to read the true zero point. It is important to regularly calibrate measuring instruments to ensure accurate and reliable measurements.
5. Can zero error be completely eliminated?
While zero error can be minimized through proper calibration, it cannot be completely eliminated. There will always be a margin of error in any measuring instrument. However, regular calibration and maintenance can help reduce the impact of zero error on measurements.
  • Classical Physics
  • Astronomy and Astrophysics
