What keeps electrons on wires?
In summary: So, in summary, if you have a wire with a negative charge, like you would get from putting metal on a charged surface, the electrons will be attracted to the surface and will not flow through the wire.
Zorodius
184
say you have a current carrying wire pointing in the +x direction, while there's an external magnetic field pointing in +y. Then the electrons in the wire feel a force towards +z.
Well, what stops them from flying off the wire? If you make the current or the magnetic field strength strong enough, can you overcome whatever it is, and tear the electrons off the wire?
They don't have enough kinetic energy to overcome the potential from the atoms.
But or course in certain circumstances electrons can be ripped of the conductor, look how an X-ray tube works for example.
could I understand this classically, or would I need quantum mechanics to understand it?
Is the potential you describe due to an attractive nuclear force?
If such a force acts on the electrons to hold them on the wire, why are they still free to move through the body of the conductor?
The electrons are not totaly free. They are bound to the crystal (the wire), but not as bound as the non-valence electrons are. The electron in the wire as (mean)velocites about 10^6 m/s, but the drift velocity (the velocity the electrons will get EXTRA due to the applied electric field) is only about 1mm/s !
And you sould also perhaps look at the Hall Effect, try google it and see if you get wiser.
interesting, thanks!
My understanding is that wires have resistance and that current travels through or over the surface of the wire. If there is less resistance over the surface, then where do you think they will go. That is not to say that electrons do not flow through the wire. In the 60's we did experiments, 'exploding wires', where the wire could not handle the current. It produced miniature 'ball lightning'.
Remember, Zorodius, an electron on a wire is still part of an atom. It is attracted to the atom's protons by the same magnetic force that any other atom has. But the thing about metals is that when you put a lot of atoms together, they act like one group of combined charges, allowing the electrons to be mobile as long as they keep the overall charge roughly neutral.
Now what if we make the overall charge negative? Have you heard of a van de Graff generator? It uses a belt and brushes (I think...) to strip electrons and put them on a metal sphere much like your shoes strip electrons off a carpet when you shuffle your feet. Those electrons do want to jump off the metal sphere and they collect on the surface of the sphere, slowly dissipating into the atmosphere. Give them an easier path (like through your finger), and they will jump off all at once, bringing the charge on the metal sphere back into equilibrium.
FAQ: What keeps electrons on wires?
What are electrons?
Electrons are subatomic particles that have a negative charge. They are a fundamental part of atoms and play a crucial role in determining the properties and behavior of matter.
How are electrons able to move through wires?
Electrons are able to move through wires due to their negative charge and the presence of an electric field. When a voltage is applied to a wire, the electric field causes the electrons to move in a specific direction, creating an electric current.
What keeps electrons from leaving the wire?
The electrons in a wire are attracted to the positively charged atoms in the wire's material. This attraction, known as the electrostatic force, keeps the electrons within the wire and prevents them from leaving.
Can electrons move in any direction within a wire?
No, electrons can only move in a specific direction within a wire due to the presence of an electric field. However, the direction of electron flow is typically opposite to the direction of conventional current flow, which is the direction of positive charge.
What happens to the electrons when the wire is broken?
When a wire is broken, the flow of electrons is interrupted and the electric current stops. The electrons will continue to move in the wire until they reach the break, at which point they will be unable to continue moving and will remain on either side of the break.
