What kind of experiment is needed to quantize gravity?
In summary: This leads to the question of how to "test" these theories. One possibility would be to use information theory to extract evidence of the theory in some other way. Another possibility would be to look for consistency between the predictions of the theory and some observational data.
Ken Gallock
30
Hi everyone.
I heard that there are several theories or hypotheses to quantize gravity such as superstring theory, loop quantum gravity, etc., and I believe none of them are conclusive (that's what I heard).
So, here is my question.
1) Is it because there are no experimental results which prove of disprove those theories?
2) If so, what kind of experimental results could lead us to an ideal theory?
We already have a quantum theory of gravity valid to energies we can currently probe:
http://arxiv.org/pdf/1209.3511v1.pdf
To go beyond that we need to experimentally probe what we currently cant, or figure out some consequence that can be checked. Its being worked on.
Thanks
Bill
Likes Demystifier
there was a paper about this on the fourth quarter MIP poll
https://www.physicsforums.com/threads/poll-fourth-quarter-2015-mip-most-important-qg-papers.851080/
here it is:
http://arxiv.org/abs/1512.02083
Tests of Quantum Gravity induced non-locality via opto-mechanical quantum oscillators
Alessio Belenchia, Dionigi M. T. Benincasa, Stefano Liberati, Francesco Marin, Francesco Marino, Antonello Ortolan
(Submitted on 7 Dec 2015)
Several quantum gravity scenarios lead to physics below the Planck scale characterised by nonlocal, Lorentz invariant equations of motion. We show that such non-local effective field theories lead to a modified Schrödinger evolution in the nonrelativistic limit. In particular, the nonlocal evolution of opto-mechanical quantum oscillators is characterised by a spontaneous periodic squeezing that cannot be generated by environmental effects. We discuss constraints on the nonlocality obtained by past experiments, and show how future experiments (already under construction) will either see such effects or otherwise cast severe bounds on the non-locality scale (well beyond the current limits set by the Large Hadron Collider). This paves the way for table top, high precision experiments on massive quantum objects as a promising new avenue for testing some quantum gravity phenomenology.
5 pages, 1 figure
one single experiment would not be expected to answer all questions. do-able experiments would constrain the possible qg theory bit by bit.
There may be some relevant idea on how to constrain QG theories here as well:
https://www.physicsforums.com/threads/poll-first-quarter-2016-mip-most-important-qg-papers.864637/
a successful qg theory may need to correctly predict the observed value of the cosmological constant (i.e. longterm expansion rate)
this may arise from the quantum microstructure underlying geometry. so here is one qg theory that makes a prediction
http://arxiv.org/abs/1603.08658
The Atoms Of Space, Gravity and the Cosmological Constant
T. Padmanabhan
(Submitted on 29 Mar 2016)
I describe an approach which connects classical gravity with the quantum microstructure of spacetime. The field equations arise from maximizing the density of states of matter plus geometry. The former is identified using the thermodynamics of null surfaces while the latter arises due to the existence of a zero-point length in the spacetime. The resulting field equations remain invariant when a constant is added to the matter Lagrangian, which is a symmetry of the matter sector. Therefore, the cosmological constant arises as an integration constant. A non-zero value Λ of the cosmological constant renders the amount of cosmic information (Ic) accessible to an eternal observer finite and hence is directly related to it. This relation allows us to determine the numerical value of Λ from the quantum structure of spacetime.
Invited Review; 32 pages; 3 figures
it's another way proposed theory can be constrained by observation
Likes bhobba
Most quantum gravity theories with gravitons would both have a coupling constant that runs with energy scale, and would also subtly influence the beta functions of the running of the Standard Model constants with energy scale. The energy scales at which this would be possible to detect probably exceed our engineering capabilities, but I could imagine astronomy observations of "natural experiments" involving very extreme circumstances that might be able to catch phenomena like this (e.g. some way to infer SM coupling constants with precision in high energy environments near supermassive black holes).
Related to What kind of experiment is needed to quantize gravity?
1. What is quantization in science?
Quantization is a process in which a continuous physical quantity, such as energy or matter, is divided into discrete units or packets. This allows for the understanding and measurement of these quantities in a more precise and accurate manner.
2. Why is quantizing gravity important?
Quantizing gravity is important because it is one of the fundamental forces in the universe and understanding it is crucial in developing a theory that unifies all the forces of nature. It could also potentially lead to a better understanding of the origins and workings of the universe.
3. What kind of experiment is needed to quantize gravity?
The type of experiment needed to quantize gravity would involve studying the behavior of gravity at the quantum level, which is currently not well understood. This could involve experiments at extremely small scales, such as using particle accelerators, or studying the effects of gravity on subatomic particles.
4. What challenges are faced in quantizing gravity?
One of the main challenges in quantizing gravity is that it does not behave like the other three fundamental forces (electromagnetic, strong, and weak) which have already been successfully quantized. Gravity is also significantly weaker than the other forces, making it more difficult to measure and study at the quantum level.
5. Has there been any progress in quantizing gravity?
While there have been various theories and attempts to quantize gravity, a complete and satisfactory theory has not yet been developed. Some progress has been made in understanding certain aspects of quantum gravity, such as the behavior of black holes, but much more research and experimentation is still needed to fully quantize gravity and unify it with the other forces of nature.
  • Beyond the Standard Models
