What makes the numbers 142[999]857 special?
  • Thread starter Thread starter AntonVrba
    Numbers
The discussion centers around the unique properties of the number 142[999]857, particularly its relationship with the repeating decimal of 1/7, which is 0.142857. Participants explore various mathematical characteristics, noting that the sum of the digits (1+4-2+8-5+7) results in 13, while an alternate calculation yields -11, leading to a difference of 2. This ties back to the number 7, suggesting a deeper connection. The number is highlighted for its short repeating sequence and its divisibility properties, although some participants express skepticism about its significance. A key point is the multiplication of 142[999]857 by integers 2 through 6, which consistently produces combinations of the same digits, indicating a fascinating aspect of its structure. The thread encourages further exploration into number theory to understand these phenomena better.
AntonVrba
1/7 = 0.14285714285714..
Well, 142+857=999, and I would assume that 142999857 is divisible with 142,999 and 857 (I haven't checked the divisibility criterion though)[/color]
142+857=999 is not part of the intended solution
But the rest is?
Master of the Obvious
:rolleyes: It only repeats as long as numbers exist?
:rolleyes: Individually they are all less than 10?
:rolleyes: It is a repeating sequence?
:rolleyes: 1+4-2+8-5+7 = 13 and 1-4+2-8+5-7 = -11 with 13-11 = 2 which is "14"/7 and "28"/7 = 4 which is twice 2 and "57" doesn't matter at all because it already has a "7" in it.
It is one of the only short sequence repeating numbers?
nice try but none of these or others above
but I like the bit about repeating but what repeats?
There's nothing special about 142857.
For example:
1/17 = 0.0588235294117647 0588235294117647 0588235294117647 ...
2/17 = 0.1176470588235294 1176470588235294 1176470588235294 ...
3/17 = 0.1764705882352941 1764705882352941 1764705882352941 ...
Notice the cyclic nature of the decimal expansion.
Well... the "142857" repeats; but that isn't really too special. I'm really either not sure what you're asking, or I'm stumped.
OK - her is the answer
2 x 142[999]857 = 285[999]714
3 x 142[999]857 = 428[999]571
upto
6 x 142[999]857= 857[999]124
the product 2x, 3x, 4x, 5x, 6x of 142[999]857 is always a combination of the same numbers, irrespective of how many times you repeat the nine in the middle
Wow! That is kind of neat. Go into the number theory forum and see if they can give a good reason as to why that is. Or do you know why that is?
  • · Replies 16 ·
