What mass of P4 is required to combine with 0.398 g of Cl2?
  • Thread starter science_rules
  • Tags
    Mass
In summary, a student is struggling to solve a stoichiometry problem involving the combination of P4 and Cl2 to produce PCl3. They have attempted to use various factors and equations, but have not been successful. Through a series of questions and explanations, they eventually arrive at the correct answers of 0.116 g P4 and 0.514 g PCl3. The expert summarizes the conversation by emphasizing the importance of understanding simple proportions in solving chemistry problems.
science_rules
158
I have tried and tried and I can't figure out the factors to use on this:
a) What mass of P4 is required to combine with 0.398 grams (g) of Cl2 to produce PCl3?
b) What mass of PCl3 results when 0.398 g of Cl2 is combined with the calculated mass of P4?
I know that the equation is already balanced but I am not sure how to write the factors to get the answers. I am teaching myself, I'm not in chemistry class, so please be patient, thank you. I still haven't gotten the hang of using factors for stoichiometry problems.
Equation to use: P4(s) + 6Cl2(g) ---> 4PCl3 (l) Unknown: P4 Known: 0.398g Cl2
I know that the atomic mass of Cl2 is 35.453 and the atomic mass of P4 is 30.973
I tried using these factors but none of them yielded the right answers: 1 mole P4/6 mole Cl2, 1 mole PCl3/137.3 g PCl3, and 1 mole Cl2/70.906 g Cl2 but none of them work. Like I said, I tried to solve it using the factors but I cannot figure out which to use, they are confusing to me.
I started with 0.00561 moles of Cl2 times 1 mole P4/6 moles Cl2 and I crossed out the Cl2 which would give 0.000935 P4 which is not the answer. The answers are supposed to be 0.116 g P4 and 0.514 g PCl3
That's not correct. The atomic mass of Cl is 35.453 u and the atomic mass of P is 30.973 u.
I just forgot to take the subscripts off
0.000935 of what? Meters? Hours?
0.000935 moles
science_rules said:
0.000935 moles
Right. So what's the molecular weight of P4? So how many grams does 0.000935 moles of P4 represent?
30.97 x 4 = 123.88 amu molecular weight, 0.028 grams in 0.000935 moles of P4 because 0.000935 moles times 30.97 =
0.028 grams
0.028 grams
##0.000935\, moles \times 123.88 \frac{grams}{mole}=??##
= 0.116 grams P4
Likes Chestermiller
Now: b) What mass of PCl3 results when 0.398 g of Cl2 is combined with the calculated mass of P4? Do I just multiply 0.398 g of Cl2 times 0.116 grams of P4?
oops, maybe not
That will give you something with units of grams2. From your balanced reaction equation, how many moles of PCl3 are produced for every mole of P4 reacted?
1 mole?
I mean 4 moles
science_rules said:
I mean 4 moles
So, if 0.000935 moles of P4 react, how many moles of PCl3 are produced?
4 moles times 0.000935 moles = 0.00374?
0.00374 moles of PCl3
Correct. You're on a roll. What is the mass of 0.00374 moles of PCl3?
2.723 grams?
science_rules said:
2.723 grams?
Where did you get that from? What is the molecular weight of PCl3 in grams per mole?
molecular weight of PCl3 = 30.97376 + 35.453X3 = 30.97376 + 106.359 = 137.33276 grams PCl3/mole
So...?
Do I divide 0.398 g Cl2 by the 70.9064 g Cl2? which would equal 0.00561 moles?
Please pay attention to what you are doing - the step you are doing now has nothing to do with chlorine, you have already correctly calculated how many moles of PCl3 are produced, and you were trying to find the mass of
Why do you step back to chlorine?
My advice:
1 draw and use pictures as I mentioned in a recent post
epenguin said:
This is a question in very starting chemistry. If this was a problem, if you needed a formula, or needed the indications of a teacher, if you were stuck by that question, and you are starting chemistry, let me suggest you do yourself a big favour:
Revise SIMPLE PROPORTIONS!
Whether it needs ten minutes and then it comes back, or whether you take a school arithmetic book and work through numbers of examples, do it till it is easy and obvious.
Because ALL the quantitative problems you will meet and be asked to solve for the first years in Chenistry will be really about nothing but proportions,
0.00374 moles of PCl3 times 137.33 grams per mole of PCl3 gives you how many grams of PCl3?
0.514 g of PCl3
epenguin said:
My advice:
thank you
Thank you for your help!
Related to What mass of P4 is required to combine with 0.398 g of Cl2?
1. What is the molecular formula for P4 and Cl2?
The molecular formula for P4 is phosphorus and for Cl2 is chlorine.
2. How do you calculate the molar mass of P4 and Cl2?
The molar mass of P4 is 123.89 g/mol and the molar mass of Cl2 is 70.91 g/mol.
3. What is the balanced chemical equation for the reaction of P4 and Cl2?
The balanced chemical equation is P4 + 6Cl2 --> 4PCl3.
4. How do you convert grams to moles?
To convert grams to moles, divide the mass of the substance by its molar mass.
5. What is the mass of P4 required to combine with 0.398 g of Cl2?
The mass of P4 required is 0.398 g divided by the molar mass of Cl2, multiplied by the ratio of P4 to Cl2 in the balanced chemical equation (4/6). This equals 0.105 g of P4.
9K
