Studying What math do I need to understand gauge theory?
Understanding gauge theory for deep learning requires a solid foundation in several mathematical concepts. Key prerequisites include set theory, group theory, linear algebra, abstract algebra, point set topology, and abstract topology. Additional courses like calculus, differential equations, and geometric algebra are also recommended, as they provide essential skills for working with vectors and surfaces. The relationship between differential forms, differential geometry, and geometric algebra is significant, with geometric algebra integrating various mathematical analyses. A thorough grasp of these topics will enhance comprehension of gauge-equivariant convolutional networks and their applications in machine learning.
Muu9
Note that I'm not interested in using it for physics, but instead for deep learning.
First off, I have to say this ML approach looks very interesting and I need to read more about it.
Here's a blog on the recent arxiv paper:
https://towardsdatascience.com/an-e...uivariant-convolutional-networks-9366fb600b70
and the paper itself:
https://arxiv.org/pdf/1902.04615.pdf
Working backward:
They mention Algebraic Topology which leads to:
https://www.math.umb.edu/~oleg/algebraic_topology
where they mention point set topology and linear algebra as prereqs
Point set topology would require group theory, abstract algebra and set theory
So the learning order would likely be:
1) Set theory
2) Group theory
3) Linear Algebra
4) Abstract Algebra
5) Point set topology
6) Abstract topology
@Euge, @fresh_42 or @Mark44 would have a better take on this though.
Likes malawi_glenn and topsquark
Can you see if this proto-book has similar prerequisites? https://arxiv.org/pdf/2104.13478.pdf
It seems to use quite a bit of formal signal theory
To what extent are topics like fibre, tangent, and vector bundles the focus of topology vs differential geometry? I feel like the latter would be more focused
Would this book be sufficient for the first 3 steps? Also, is this the appropriate thread for my question?
having read a little bit of the book, it seems you should also take these standard math courses in parallel:
- Calc 1,2,3
-Differential Equations
- Geometric Algebra
while they may not have direct bearing on the ML topic, Calc 3 in particular works with vectors, surfaces and volumes and Differential Equations can lead to Partial Differential Equations which also does a lot with surfaces and volumes. It doesn't hurt to know more math. Geometric Algebra brings together many of the vector and tensor concepts that again may help in understanding some of the transformations that are done.
Set theory is important as a means to learn mathematical proof using the set definitions as a basis. Proof becomes more important as you move up the chain to Group Theory, Abstract Algebra, Pointset Topology and then Abstract.
When I was a Physics student I jumped into Abstract topology as a junior and was overwhelmed by the definitions and the proofs. At the time, I thought my understanding of proofs from HS Geometry would get me through. Nope. I would get lost is the nested nature of the definitions and found I couldn't prove a thing.
I guess I thought Abstract Topology would have more in common with the popular rubber sheet topology but its all very theoretical. My prof was kind and gave me some leeway, knowing that I was not a math major but that was more than forty years ago.
There's a book called All the Math You Missed but Need to Know for Graduate School by Prof Thomas Garrity
https://www.amazon.com/dp/1009009192/?tag=pfamazon01-20
that might help here too. It summarizes some of the courses I mentioned earlier as chapters in the book ie Point Set topology, linear algebra, calculus 1,2,3, abstract algebra, and parts of geometric algebra in the form of differential forms.
Are you referring to the geometric deep learning proto-book I linked to, or the abstract and linear algebra book I linked to?
Can you explain how differential forms, differential geometry, and geometric algebra are related (as courses, not as mathematical concepts)? Which order should I study them, and are any a special case/subtopic within another?
Geometric algebra neatly ties together vector analysis, tensor analysis, differential forms and differential geometry.
As an example, the vector cross product only makes sense in 3D as the area of a parallel and as a normal to a surface element. However, in geometric algebra it makes sense as a bivector in 2D as well as higher dimensions.
https://en.wikipedia.org/wiki/Geometric_algebra
Here's a 40+ minute tutorial on geometric algebra:
TL;DR Summary: What topics to cover to safely say I know arithmetic ? I am learning arithmetic from Indian NCERT textbook. Currently I have finished addition ,substraction of 2 digit numbers and divisions, multiplication of 1 digit numbers. I am moving pretty slowly. Can someone tell me what topics to cover first to build a framework and then go on in detail. I want to learn fast. It has taken me a year now learning arithmetic. I want to speed up. Thanks for the help in advance. (I also...
Hi community My aim is to get into research about atoms, specifically, I want to do experimental research that explores questions like: 1. Why do Gallium/Mercury have low melting points 2. Why are there so many exceptions and inconsistencies when it comes to explaining molecular structures / reaction mechanisms in inorganic and organic chemistry 3. Experimental research about fundamental Quantum Mechanics, such as the one being followed by Hiroshima university that proved that observing...
guys i am currently studying in computer science engineering [1st yr]. i was intrested in physics when i was in high school. due to some circumstances i chose computer science engineering degree. so i want to incoporate computer science engineering with physics and i came across computational physics. i am intrested studying it but i dont know where to start. can you guys reccomend me some yt channels or some free courses or some other way to learn the computational physics.
