What other information is needed to solve this equation involving b?
The discussion revolves around solving for the damping coefficient "b" in the equation for a damped harmonic oscillator influenced by friction. The equation provided involves parameters such as amplitude (A), spring constant (k), mass (m), and phase (φ), with specific values given. It is noted that as "b" increases, the oscillations will eventually cease, leading to a period approaching infinity. Participants clarify that "clearing for b" means solving the equation for "b," and the expected answer is 7.746 kg/s. Understanding the relationship between the parameters and the behavior of the system is essential for finding the correct value of "b."
leomarrg
Consider the movement of the mass and spring with friction
A * [e ^ - (b / 2m) t] * cos (sqrt (k / m - (b / 2m) ^ 2)) t + φ)
With A = 2m, k = 3N / m, m = 5Kg and φ = 0, we could change to the value of "b" from zero until the oscillations disappear for the first time and the function does not change to negative values. In this case, the friction now has a very noticeable effect: it lengthens the period of the oscillation so much that no oscillations will be seen (T -> infinity).
The theory indicates when that should happen. Clear for b from the equation and record the predicted value for b = .... (Kg / s) (at least two decimal places to the right of the point)
The question is complete, the exercise is clear for b, I don't get how to do it. The answer is 7.746
the equation is not equal not to anything (example: 3x = 6) and i don't know how to resolve [e ^ - (b / 2m) t].
leomarrg said:
Homework Statement:: Consider the movement of the mass and spring with friction
The theory indicates when that should happen. Clear for b from the equation and record the predicted value for b = ... (Kg / s) (at least two decimal places to the right of the point)
Relevant Equations:: A * [e ^ - (b / 2m) t] * cos (sqrt (k / m - (b / 2m) ^ 2)) t + φ)
Then it's not an equation.
Why does the friction change the period of oscillation? When the damped oscillator crosses zero, it is moving faster than at any other point since it last came instantaneously to rest. Yes, the period depends on bb but for a given bb it is constant.
What are you trying to find? If it is b, you need to know the position at some other time or the velocity at ##t=0##.
You have ##x(t)=Ae^{-{\frac{b}{m}t}}\cos(\omega t).## What do you get when you substitute ##t=0## in this expression?
I get 2
leomarrg said:
I get 2
That is incorrect. When you substitute ##t=0##, you get
##x(0)=Ae^{-\frac{b}{m}*0}\cos(\omega*0)##. What does that simplify to?
my bad, was using the data given in the exercise, A?
Write the equation to which the equation in post #6 simplifies. ##A## is not an equation.
x(0) = A?
e^−b/m * 0 = 1, and cos(w * 0) = 1
leomarrg said:
x(0) = A?
Yes. Now what? What is the question you want us to help you with?
clearing this for b. The complete exercise is on the first question. If t = 0 then cos (sqrt (k / m - (b / 2m) ^ 2)) t is going to = 0. the answer is 7.746 but i don't know how to get there...
I do not understand what "clearing this for b" means. Specifically, what does "clearing" mean and what "this" is that needs to be "cleared". Perhaps you can post an example in which something is "cleared" for b or whatever.
I'm translating this question, it was given on a quiz it's original language is Spanish and i don't know if the correct term is clear for b, but essentially i want to know the value of b. That's what i mean by clear. Already have A, m, k, and φ
The correct word is "solve" for b. OK, now that we have settled that, what do you know other than
##x(t)=Ae^{-\frac{b}{m}t}\cos(\omega t)## and the values for ##A##, ##m##, ##k## and ##\phi##?
  • · Replies 19 ·
