Anon42
- 6
- 2
- TL;DR Summary
- What is the strength of the electric field of an electron just outside of the electron, and is it strong enough to enable pair production?
Coulomb's law for three dimensional space is an empirical law that describes the forces between two stationary point charges and is defined as:
[tex]\vec{F}=\frac{K q_1 q_2 (\vec{r}_1-\vec{r}_2)}{|\vec{r}_1-\vec{r}_2|^3}[/tex]
From Coulomb's law, the magnitude and direction of an electric field produced by a point charge can be modeled. [itex]q_2[/itex] is removed from the original equation, as is [itex]{r}_2[/itex]. The cartesian coordinate system is then defined so that the origin of the coordinate system is the point charge and the vector [itex]{r}_1[/itex] always originates from the origin. The equation then becomes:
[tex]\vec{E}=\frac{K q_1 \vec{r}_1}{|\vec{r}_1|^3}[/tex]
Is it possible to define the magnitude of [itex]{r}_1[/itex] as the charge radius of an electron [itex](2.82 ⋅ 10^{-15} m)[/itex] plus a couple Planck's constants[itex](6.62607004 ⋅ 10^{-34} \frac{m^2}{kg⋅s})[/itex] and get a meaningful result? The Planck constants are added on to the electron radius to make sure that the electric field solved for is in fact outside of the electron. For good measure, we can let [itex]|{r}_1|=3.00 ⋅ 10^{-15} m[/itex]
So for our equation, the variables are defined as:
[itex]q_1[/itex] is taken be the charge of an electron, [itex]1.60217662 *10^{-19} C.[/itex]
[itex]{r}_1[/itex] is taken to be the magnitude and direction of a position in space with the vector originating from the electron with: [itex]|{r}_1|=3.00 ⋅ 10^{-15} m[/itex]
[itex]K[/itex] is taken to be the Coulomb Constant [itex]8.9875517923 * 10^{9} \frac{kg⋅m^{3}}{s^{2}⋅C^{2}}.[/itex]
I tried solving this equation for electric field strength just outside an electron say in some arbitrary x-direction and got the following:
[tex]\vec{E}=\frac{8.9875517923⋅10^{9} \frac{kg⋅m^{3}}{s^{2}⋅C^{2}} 1.60217662⋅10^{-19} C⋅[3.00 ⋅10^{-15} m, 0 m, 0 m]}{|3.00 ⋅10^{-15}|^3}[/tex]
[tex]\vec{E}=1.599960595 ⋅10^{20} \frac{V}{m}[/tex]
If this calculation is done right, then an electron has an electric field strength of roughly [itex]10^{20} \frac{V}{m}[/itex] in the space just outside of it!
However, Wikipedia states that the Schwinger limit, the limit which the electromagnetic field becomes nonlinear occurs at roughly [itex]10^{18} \frac{V}{m}.[/itex] Electron-positron pair production happens at fields at and above the Schwinger limit. Every electrons in the universe doesn't spontaneously produce electron-positron pairs. That leads me to believe that the electric field strength just outside of an electron must somehow be less than [itex]10^{20} \frac{V}{m},[/itex] and closer to [itex]10^{18} \frac{V}{m}.[/itex]. Either that or the field is in fact on the order of [itex]10^{20} \frac{V}{m},[/itex] and some quantum mechanism prevents pair production near electrons.
My question is this: Did I make a mistake in calculating the electric field strength just outside of an electron? If not, then why don't all electrons spontaneously generate electron-positron pairs? Or am I just misunderstanding the Schwinger limit in some way? The electric field strength just outside of an electron is enormous. How does our current understanding of QED describe this?
