What part of the Moon am I looking at?
  • B
  • Thread starter lifeonmercury
  • Tags
    Moon
In summary, the conversation discusses the position of the moon in the sky from a vantage point near the equator. The top point of the moon is approximately at the lunar equator and the lunar poles are 90 degrees away at the sides. However, it is mentioned that you can never see both poles at the same time due to the moon's axial tilt and the Earth's axis of rotation. The conversation also touches on the effect of libration, the visibility of the moon's surface, and the impact of the moon's tilt on its appearance in the sky. It is suggested to use a diagram or a simulation program to better understand these concepts.
lifeonmercury
137
I'm standing at a location near the equator and see a full moon in the sky overhead. From my vantage point, the top point of the Moon is (approximately) at the Lunar equator and the Lunar poles are 90 degrees away at the sides. Is this correct?
Astronomy news on Phys.org
It depends how you define, "the top point of the moon". Is the moon directly overhead (i.e. at the zenith)? If so, which point is the "top"? If it is not at the zenith, where in the sky is it?
A bit above the horizon. The top meaning the point on the Moon furthest up in the sky.
I think it's much more complicated than you say. It depends where on the ecliptic the moon is, since this will determine the angle between the ecliptic and the horizon. Also, the axis of the moon's orbit is tipped 5 degrees relative to the ecliptic plane, and the Earth's axis of rotation is tipped 23 degrees relative to the ecliptic plane. Why don't you try sketching it out when the moon is on the celestial equator, at it's highest point above the equator, and at its lowest point below the equator?
You can never see both poles at the same time. There is a significant shortfall when the object you are looking at is as large and near as the Moon.
A bit of trigonometry would tell you just how much is invisible.
The moon's polar axis is also tilted 6.687 degrees to its orbital plane, which gives the moon a ~1.54 degree axial tilt to the ecliptic.
That effect is smaller than 1% for a perfect sphere: You can see more than 49% of that idealized sphere. Mountains etc. lead to additional surface area you cannot see, but it also leads to points beyond the idealized horizon that are visible.
Because of libration, we see much more than half of the Moon's surface so that 1% is not very relevant.
The effect is much more relevant for satellite observations (only around 2200km for the ISS), where the distance is a lot smaller. The effect of reducing the distance to the horizon is even worse when you are in a small boat at sea, when it reduces to zero in the limit.(Except when viewing high objects, of course)
Still having trouble grasping this concept unfortunately. When I see a half-moon in the sky divided diagonally (the dividing mark between the light and dark halves is not straight up and down), does that mean the lunar poles are approximately at the two ends where dark and light converge?
Have a look at the diagram http://ccar.colorado.edu/asen5050/projects/projects_2011/lestishen/extension.html. That shows the angles involved. The sun lies in the plane of the ecliptic and none of the angles of the Earth's rotation, the Moon's rotation or the Moon's orbit are zero. Also, your view from the Earth will be affected by your latitude. A simple model of the system will not show you exactly what you will see.
The lunar axis will appear to be (approximately) horizontal when viewed from the Equator and (approximately) vertical when viewed from the poles. The position of the full Moon in the sky will vary in azimuth as the year progresses. In winter, the Sun appears low in the sky but the full moon (being the opposite side of Earth) will appear high but not by the same amount every year. The diagram in the link shows this situation. The opposite applies in Summer. But the Moon has its own tilt and so you will see more or less of each pole, depending where the lunar month phase is related to the Solar year (everything is out of sync).
The Moon has its own version of Summer and Winter because of the tilt of the axis to the ecliptic.
Do some waving of the hands around that diagram and see what happens as the bodies orbit and rotate.
Alternatively, get hold of a (free) copy of Stellarium and, after a few hours of practice (unfortunately for you) you can simulate all of it. Red Shift (not free) will show you these things happening from other points in space, once you have learned to drive it.
Likes lifeonmercury
Thanks. This fully answers my question. I will have a look at the diagram anyway.
Google Images has pages and pages of pictures of what you want. Search terms like tilt of the moon's orbit etc. Very entertaining.
Related to What part of the Moon am I looking at?
1. What causes the different phases of the Moon?
The different phases of the Moon are caused by the relative positions of the Moon, Earth, and Sun. As the Moon orbits around the Earth, the amount of sunlight that is reflected off of its surface changes, resulting in the different phases we see from Earth.
2. How can I determine which part of the Moon I am looking at?
The part of the Moon you are looking at can be determined by its phase and the time of day. If you know the current phase of the Moon, you can use a lunar phase calculator or app to determine which part of the Moon is facing Earth.
3. What is the difference between the near side and far side of the Moon?
The near side of the Moon is the side that is always facing Earth, while the far side is the side that is always facing away from Earth. The near side is the only part of the Moon that has been explored and photographed by spacecraft.
4. Can I see the same part of the Moon from different locations on Earth?
Yes, you can see the same part of the Moon from different locations on Earth. However, the angle at which you view the Moon may be slightly different, resulting in a different perspective of the same lunar features.
5. How does the tilt of the Moon's orbit affect what part of the Moon we see?
The tilt of the Moon's orbit does not affect what part of the Moon we see. The Moon's orbit is always in the same plane, so the same part of the Moon is always facing Earth. However, the tilt of the Moon's orbit does affect the angle at which we see the Moon from Earth, resulting in the changing phases.
  • Astronomy and Astrophysics
