jc09
- 45
Hi just wondering if anyone could tell me why the Z boson can couple to any standard model particle except forgluons and photons?
kaksmet said:A second way to see it is that the photon only couple to particles with charge
Vanadium 50 said:That's often written, but it's not correct. A photon can couple magnetically to an uncharged object (like a neutron).
In the context of the standard model the photon coupling to neutral particles is zero at tree level. The only way the photon couples to neutral particles (including itself and the Z boson) is via higher order corrections. The standard model does not contain a neutron as a fundamental degree of freedom so it's missleading to discuss couplings to fundamental particles and to effectice degrees of fredom on an equal footing.Vanadium 50 said:But before we knew about quarks, we knew the photon coupled to the neutron magnetically. There is no trouble with writing a magnetic coupling.
A Z boson is a subatomic particle that carries the weak nuclear force. It is an elementary particle, meaning it cannot be broken down into smaller particles.
Coupling refers to the interaction between two particles. In the case of Z bosons, coupling explains how they interact with other particles, such as fermions, to transmit the weak nuclear force.
Z boson coupling is explained through the Standard Model of particle physics. This theory describes the fundamental particles and forces that make up our universe, including how Z bosons interact with other particles.
Understanding Z boson coupling is crucial in order to fully understand the weak nuclear force and its role in the universe. It also helps scientists make predictions and test the accuracy of the Standard Model.
The study of Z boson coupling has practical applications in fields such as nuclear energy, medical imaging, and particle accelerators. It also helps us understand the origins and evolution of the universe.
