Automotive What particular mechanic or engineer does this work?
A mechanical engineer is the professional qualified to design and create a hydraulic car lift using CAD software. This engineer can develop new arrangements of hydraulic valves, cables, and other components necessary for the lift's operation. The lift operates through electrical switches and motors or hydraulic valves, emphasizing the importance of mechanical interlocks for safety. No specialized software is required for controlling the lift, as it relies on these mechanical and electrical systems. The discussion highlights the specific expertise needed for such mechanical design and safety considerations in auto repair environments.
cat-lessDude
TL;DR Summary
Hi, I would love to understand how to create a software for controlling a hydraulic car lift.
Hi, making the thread again since I posted a pic with a link, so I apologize.
What particular mechanic or engineer can design/create (using a CAD, new software, etc), a hydraulic car lift to mechanically lift a car? Plus its accessories/machinery/cables in a regular auto repair shop, for the mechanic to work underneath?
What specific expertise is this?
Who can create a software for controlling this machine?
Folks, this is my question since I am not educated in your area.
Welcome to PF.
The machine would be designed by a Mechanical Engineer.
The machine does not require software. It is controlled by electrical switches and motors, or by hydraulic valves. Mechanical interlocks are required, without software, because safety is very important.
Likes russ_watters and cat-lessDude
Hello, Baluncore:
Thank you for be my first reply. You rock!
I mean, who do this? Any mechanic or engineer? Or it is a separate expertise, example, let's say Hydraulic mechanic,,,?
No, no, you already answered: a Mechanical Engineer.
So, a mechanical engineer could create in CAD a "new" type of hydraulic valves and cables.
So, a mechanical engineer could create in CAD a "new" arrangement of hydraulic valves and cables, chains or screws.
Likes cat-lessDude
Baluncore:
Again, thank you a lot for the answers in educating me about this.
I may comeback with other questions during the weekend.
Have a good day, you and every member here!
Thank you again)
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
