What path does matter take after entering a black hole?
In summary, if an outside observer could see inside the event horizon, they would see matter spiraling towards the event horizon and then taking a direct path to the center.
  • #36
PeterDonis said:
The best answer to your underlying question is the one I gave in a previous post a little bit ago: none of the relevant properties of the thing that is falling in change when it crosses the horizon. Locally the thing can't even tell that it's crossed the horizon. So you should not expect any drastic change in the "trajectory" of the thing (to the extent that term is well-defined) when it crosses the horizon.
...and the one I gave waaayy back in post 19... :wink:
"...there is nothing special about the event horizon as regards to trajectory. It's not a barrier or boundary; it is simply a geometrically-defined surface below which light (et al) cannot escape.
An infalling observer will not experience anything unusual passing through the EH; in fact he won't even know without doing some measurements and calculations (quickly!)."
  • #37
PeterDonis said:
The fact that "trajectory" usually means a path in space, not spacetime, and in a non-stationary spacetime there is no invariant notion of "space".
Ah - I see your point. I think you are using a fairly strict definition of "trajectory", but fair enough.
  • #38
The obvious alternative meaning would be "worldline", i.e., the curve in spacetime that describes the object's history. The object certainly does continue to have a worldline when it falls through the horizon, and that worldline continues to be a curve in spacetime, yes.
Likes timmdeeg
  • #39
I'm not aware of calculations in textbooks, where one consideres the general motion of a test mass around a (say Schwarzschild) black hole except the most simple case of radially falling towards the center. For that example you realize that nothing special happens at the event horizon, because there's nothing special their. The singularities are only coordinate singularities at the Schwarzschild radius. The motion of the particle is just smooth across the event horizon. There's only the singularity at the origin of the black hole.
  • #40
Does the worldline of an object inside a Schwarzschild black hole depend on any deviations from a radial path outside?
  • #41
Or instead something else because physics breaks down there.
Likes vanhees71
  • #42
Yes indeed, I think singularities are a clear manifestation of our ignorance, and classical point-like objects always make trouble and the theories inconsistent (like in the less complicated case of electrodynamics, where classical point particles simply don't work, i.e., there's no fully consistent dynamics of classical point charges and the em. field).
  • #43
Do you think that a future theory of quantum gravity (if we ever will have it) will shed light also onto this inconsistency (besides singularity)?
  • #44
A naive question: If light cannot escape from the interior of a black hole then doesn't that say something about the light cones? Wouldn't they define bounded trajectories for light? Wouldn't a body with mass have to stay within these cones and would also follow a bounded trajectory? If there is a inevitable singularity would the light cones have to converge to it somehow?
  • #45
Try this:
  • #47
lavinia said:
Which is just another question based on the misapprehension that ##r## is a spacelike coordinate inside the event horizon. Inside the horizon, you still have three spatial dimensions to move around in. The inevitable singularity is not in any specific spatial direction. And it's your time evolution, as it were, that leads you towards it.
Try the PBS video.
  • #48
Yes
Yes
Yes
No, because the singularity isn’t a place is space so there’s nothing to converge on. If you draw a spacetime diagram on a piece of paper, the singularity will be a place on the paper where worldlines just end - whether it’s represented as a point on the paper or a larger region that cuts across an entire light cone depends on how you map points in spacetime to points on the sheet of paper.
In a traditional Minkowski SR spacetime diagram we plot ##t## on the y-axis of our sheet of graph paper and ##x## on the x-axis. This doesn’t work in curved spacetime of course, but we can instead use Schwarzschild coordinates and plot the ##r## coordinate on the x-axis of our graph. When we do this the singularity appears as a vertical line at the origin and the light cones are tipped sideways so that both sides of any light cone with its base inside the horizon will intersect that line. So everything ends up reaching the singularity, but that doesn’t imply convergence.
A spacetime diagram drawn using Kruskal coordinates is particularly helpful in visualizing how light cones relate to the event horizon and the singularity because in those coordinates lightlike worldlines are drawn at the same 45-degrees-from-vertical angle as on the Minkowski diagrams that know from special relativity. The singularity is drawn across the entire top of the sheet of graph paper.
(You may be wondering why I’m making such an effort to distinguish between points in spacetime and points on the surface of the sheet of graph paper. The reason is that the singularity is not part of spacetime at all. No matter what coordinate system I use to map points in spacetime to points on the sheet of paper, there will be points on the sheet of paper that do not correspond to any point in spacetime, and those represent the singularity. A worldline that encounters the singularity... just ends because there’s no “next” point to advance to).
Likes vanhees71
  • #49
Of course it does; why wouldn't it? There is nothing magical at the horizon that erases tangential motion.
Likes vanhees71
  • #50
Try the PBS video.
read the answers
  • #51
Will a non-radial path be deflected towards radial (though not reaching radial at the horizon) with decreasing distance to the horizon? And is the intuition correct that an increasing non-radial worldline within the black hole will take increasing proper time to reach the singularity?
  • #52
lavinia said:
read the answers
lavinia said:
There are a couple of good answers in that thread from stackexchange you linked above. I only glanced at the first two, John Rennie's and Lubos' Mott's answers. Are you satisfied with those answers? Do you have any furhter qu4estions? Your responses are rather terse, I'm not quite sure if there's a need to say anything else.
Likes PeroK
  • #53
Why would it be deflected? As has already been pointed out multiple times, there is nothing magical at the horizon.
What do you mean by "increasing non-radial worldline"?
  • #54
For the moment yes. Thank you for asking.
- I was a little surprised that answers given in this thread used coordinate systems. It would seem that light cones are regions of the tangent bundle so one ought to be able to give a coordinate free description of their behavior. I later found pictures on line. One came from a book by someone named Geroch which showed the convergence of light cones to the singularity. BTW: This convergence seems real even though the singularity formally is not a part of space-time. I suppose there is a completion of the space-time manifold to include the singularity in which convergence does take place.
- The answers given here were all in terms a single point singularity and I would have thought that there is a more general answer that allows for a distribution of singular points, not just a single point. Suppose for instance that the singularity forms a two dimensional surface. This would still imply infinitely dense matter and should form a black hole.
  • #55
I was assuming that the trajectory of a non-radially infalling object is bent towards the center of mass such that it approaches but not necessarily reaches a radial path. Is that wrong?
  • #56
In what way, if any, is your mental picture of a black hole inside the event horizon different from the region around a Newtonian point mass? Which is also a singularity.
  • #57
It's not generally true. Qualitatively, GR orbits outside ##3R_S/2## aren't radically different from Newtonian orbits, which includes open orbits that are nearly radial, become tangential, then become nearly radial outward again. However, all free-fall orbits that graze ##3R_S/2## fall in, which is not a feature of Newtonian physics. And null trajectories are correctly handled in GR, where there isn't a clearly correct way to do it in Newtonian physics.
I'm not certain that "approaches radial" is ever a correct description of orbits nearing the centre of a spherically symmetric gravitational fields (remember that tossing a ball on Earth is the aphelion end of a very eccentric orbit whose perihelion would be deep in the core). Angular momentum is conserved, and is not affected by the field, so the tangential velocity must increase as the orbit gets lower. Certainly for open and stable orbits your characterisation is incorrect, but I haven't done the maths for orbits that fall into a black hole.
Likes PeroK
  • #58
My remark concerned the outside of the horizon and I have replaced "deflected" by "bent" hoping that then I express myself better. Inside r- and t-coordinates are changed and I think a comparison with a Newtonian trajectory doesn't make sense. But please elaborate on this if I'm wrong.
  • #59
I seem to be wrong what "orbit" means, I thought orbit means circling around.
I am talking about an object on a non-radial trajectory falling through the event horizon. Searching the web I couldn't find anything about non-radial fall into a black hole.
  • #60
Yes sure. There's a downwards force, causing an increase of downwards speed, and a decrease of horizontal speed. It's the time dilation effect. Or the the effect that sometimes in relativity acceleration points to other direction than force.
If we are interested about momentum, downwards momentum increases, horizontal momentum stays constant.
(I'm not saying anything about the "within the black hole" -part)
Likes timmdeeg
  • #61
Ok, thanks. :smile:
  • #62
This looks like an analysis of Newtonian gravity with some SR concepts thrown in.
  • #63
I certainly use the word to describe anything like planets' and comets' paths, which can be open or closed. Newtonian physics doesn't have the concept of a "must crash" trajectory except for a purely radial one, so I think "must crash" trajectories in GR are called orbits as a natural generalisation. I could be wrong.
Edit: there's an error in the following - see #89 for the correction.
For a particle with four-velocity ##U^\mu##, the cosine of the angle its path makes with a radial inward four vector ##R^\nu## is ##g_{\mu\nu}U^\mu R^\nu## (strictly I should restrict myself to summing over the spatial components, but that turns out not to matter here). In Schwarzschild coordinates, the metric is diagonal and the only non-zero component of ##R^\nu## is ##R^r=-1/\sqrt{g_{rr}}##, which means that ##\cos\psi=-\sqrt{g_{rr}}U^r##, where ##\psi## is the angle between the path and the radial direction.
For a free-falling particle on an inward path, Carroll's GR lecture notes 7.47 and 7.48 tell us that $$U^r=-\sqrt{E^2-\left(1-\frac {R_S}r\right)\left(1+\frac{L^2}{r^2}\right)}$$which means that the angle ##\psi## the path makes with the radial-inwards direction is given by$$\cos\psi=\sqrt{{{E^2}\over{1-{{R_S}\over{r}}}}-{{L^2}\over{r^2}}-1}$$The derivative of this with respect to ##r## is$${{\sqrt{R_S-r}\left(2L^2R_S^2+\left(-4rL^2-r^3E^2\right)R_S+2r^2L^2\right)}\over{\sqrt{rL^2-\left(L^2+r^2\right)R_S-r^3E^2+r^3}\left(2r^2R_S^2-4r^3R_S+2r^4\right)}}$$Evaluating this at ##r=3R_S/2##, the limit below which you cannot dip and recover, gives us$${{2\left(4L^2-27E^2R_S^2\right)}\over{9R_S^2\sqrt{27E^2R_S^2-4L^2-9R_S^2}}}$$If this is positive, falling ##r## means falling ##\cos\psi## and hence increasing ##\psi## - so the path is getting further away from radial. If it is negative then the path is getting closer to radial. But note the denominator - it is only real if ##27E^2R_S^2-4L^2>9R_S^2##, which implies that the numerator is negative.
So, yes, if my maths is correct, paths that strike the black hole are getting closer to radial, at least as they cross ##3R_S/2##. As noted earlier, this is not true of paths that do not strike the black hole.
Likes timmdeeg
  • #64
I missed this earlier - no, it's not true. The maximal survival time from striking the black hole comes from being dropped from rest just above the horizon. That is, accelerating to get as close to the path of a radially free-falling object coming from just above the horizon maximises your survival time.
  • #65
This certainly isn't generally correct, as discussed in #57. And I'm not sure what you mean by "horizontal momentum". The angular momentum, ##L##, is a constant of the motion. The component of linear momentum in the tangential direction (##\propto L/r##) is not.
  • #66
Thanks for investing so much time.
I am trying to see what happens at ##r=R_S##. Here ##1-R_S/r## approaches zero. So it seems that ##\cos\psi## approaches a maximum and thus ##\psi## approaches zero. (however ##\psi=0## requires ##\cos\psi=1##). Does that mean a radial path at the event horizon regardless any arbitrary initial non-radial path?
  • #67
And why were you assuming that? Where would this magical influence that somehow changes the trajectory of the object come from?
  • #68
That means those coordinates don't work at the horizon. I'd have to think a bit about exactly what "radial" means at the horizon.
  • #69
This is the effective potential formulation, and is only valid outside the horizon. It doesn't help for the question under discussion here, which is to describe what happens to an object that falls through the horizon.
  • #70
You can't from the equations you are looking at. Those equations are only valid outside the horizon. See my response to @Ibix just now.
