What percent of the sky can an astronomer see at one time?
In summary: That was to find the max θ for your integral. You gave the correct formula for the solid angle, which measures the area of the spherical cap.
charlie05
128
The astronomer fell into the well. The well is circular, depth H = 15m, radius r = 1m. The astronomer has eyes at h = 1.75m. Observation is from the well axis, refraction is neglected.
How many % of sky can an astronomer see at one time?
How many % of sky can an astronomer see during the whole year?
sine theorem, cosine theorem od sides and angles
tg alfa=1/13,25...alfa=0,0013°.
2D well viev...2*alfa=0,0026°
but view is 3D...have I use solid angle? normally an astronomer could see 2π?
Since the view is 3D, you should indeed solid angles to calculate the angle of vision. First consider the case were the astronomer is outside the well. In this case, he sees the 100% of the sky (assuming you call 100% seeing the whole half hemisphere on where they're standing). So the solid angle would be ##\Omega=2\pi##.
When the astronomer is at the bottom of the well, he is in a cylinder of height 15 m and radius 1 m and his eyes reach up to 1.75 m (assuming he's looking upwards and at the center of the well). Since the differential solid angle is ##d\Omega=sin\theta dr d\theta d\phi##, you must integrate within the small region of the well that they can see. The integration on ##\phi## is trivial since it goes from ##0## to ##2\pi##, while for ##\theta## you must consider the region they can see from the well.
I cannot draw here, but imagine a triangle rectangle that goes from the eyes of the astronomer to the corners of the well, which has a height of 13.25 m, side of 1 m, and hypothenuse of 13.2877 m. Thus you immediatly see that ##sin\theta_w=1/13.2877## and ##\theta_w=arcsin(1/13.2877)##. So your integration goes from ##0## to ##\theta_w##. Compare it to ##2\pi## and you get the percentage.
As for how much it will see during the year, you must factor the rotation of the Earth and estimate how much the solid angle will change over time. I haven't worked the math on that one, so I'll leave it to you.
Likes charlie05
Thank you very much for your help, this is amazing and I understand it...
Likes CharlieCW
Given the depth to width ratio, probably good enough to consider the area at the top of the well as a flat disc.
Likes CharlieCW
Indeed, in my answer I'm basically considering the top of the well as a flat disk to find an expression for the angle ##\theta##.
I am suggesting just taking the area of the flat disc, no integral needed.
Related to What percent of the sky can an astronomer see at one time?
1. What does "percent of the sky" refer to in astronomy?
"Percent of the sky" refers to the amount of visible sky that an observer can see at a given time. In astronomy, this is often used to describe the portion of the celestial sphere that is visible from a specific location on Earth.
2. How is the "percent of the sky" calculated?
The "percent of the sky" is calculated by dividing the visible area of the sky by the total area of the celestial sphere. This value is then multiplied by 100 to get a percentage.
3. What factors affect the "percent of the sky" an astronomer can see?
The "percent of the sky" that an astronomer can see is affected by several factors, including the time of day, the location on Earth, and the weather conditions. The presence of clouds, light pollution, and atmospheric conditions can also impact the visibility of the sky.
4. Is it possible for an astronomer to see 100% of the sky?
No, it is not possible for an astronomer to see 100% of the sky at one time. This is because the Earth's atmosphere limits the amount of sky that is visible, and there will always be a portion of the celestial sphere that is blocked by the horizon.
5. How does the "percent of the sky" change throughout the day?
The "percent of the sky" changes throughout the day as the Earth rotates on its axis. At any given time, an astronomer can only see the portion of the sky that is above the horizon. As the Earth rotates, different portions of the celestial sphere become visible, resulting in a change in the "percent of the sky" an astronomer can see.
