What percentage of the bits on a CD is dedicated to error-correction?
  • Thread starter hitemup
  • Tags
    Bits
In summary: CD_DA In summary, on an audio compact disc, digital bits of information are encoded sequentially along a spiral path. A CD player's readout laser scans along the spiral's sequence of bits at a constant speed of 1.2 m/s, with each bit occupying 0.28 micrometers. The number of digital bits read every second is 4.3*10^6, with 67% of the bits dedicated to encoding and error-correction.
hitemup
81
On an audio compact disc, digital bits of information are encoded sequentially along a spiral path. Each bit occupies about 0.28 micrometers. A CD player's readout laser scans along the spiral's sequence of bits at a constant speed of about 1.2 m/s as the CD spins.
a) Determine the number N of digital bits that a CD player reads every second.
b) The audio information is sent to each of the two loudspeakrs 44,100 times per second. Each of these samplings requires 16 bits and so one would think the required bit rate for a CD player is
N0= 1.4*106 bits/second. The excess number of bits(N-N0) is needed for encoding and error-correction. What percentage of the bits on a CD are dedicated to encoding and error-correction?
The attempt at a solution
1.2 / (0.28 * 10^-6) = 4.3 * 10^6 bits per second.
((4.3-1.4)/ 4.3) * 100 = 67% for encoding and error correction.
Having seen the high percentage, I've thought that something may have gone wrong, so I ask for your help to make sure if I solved this correctly or not.
The logic looks right to me.
In your linked thread, it looks like they added a zero somewhere. 1.2/.28 = 4.286. m/##\mu##m=##10^6##. I agree that 67% seems high for error correction, but from the information you have posted, it could not be anything else.
##\frac{1bits*1.2m}{.28 (10^{-6})m * sec}## is N
##\frac{(N-N_0)}{N} ## is the proper proportion.
If your initial numbers are correct, you should be confident in your method.
Likes hitemup
From wiki article: with this, a frame ends up containing 588 bits of "channel data" (which are decoded to only 192 bits music) , so 396 bytes of overhead for encoding, error correction, ... , which corresponds to ~67.347% overhead.
ce data encoding.htm
Likes hitemup and RUber
Related to What percentage of the bits on a CD is dedicated to error-correction?
1. How much of a CD's storage capacity is used for error-correction?
The amount of error-correction on a CD is typically around 25% of the total storage capacity. This means that for every 4 bits of data, 1 bit is dedicated to error-correction.
2. Why is a significant portion of a CD's capacity dedicated to error-correction?
Error-correction is necessary in order to ensure that the data on a CD is read accurately and without errors. CDs are susceptible to scratches and other damage, so error-correction helps to minimize the impact of these imperfections on the data.
3. Can the amount of error-correction on a CD be adjusted?
The amount of error-correction on a CD is determined during the manufacturing process and cannot be adjusted afterwards. However, different types of CDs may have varying levels of error-correction depending on their intended use.
4. How is the error-correction on a CD calculated?
The error-correction on a CD is calculated using a mathematical algorithm called Reed-Solomon error correction. This algorithm allows for the detection and correction of errors on the CD.
5. Is there a limit to how much error-correction can be used on a CD?
Yes, there is a limit to how much error-correction can be used on a CD. If too much of the storage capacity is dedicated to error-correction, there may not be enough space for the actual data. This can result in a lower overall quality of the data on the CD. Therefore, the amount of error-correction is carefully balanced to ensure optimal performance.
  • Quantum Physics
11K
  • Beyond the Standard Models
  • Atomic and Condensed Matter
