What Polynomial Pairs Satisfy These Complex Functional Equations?
  • MHB
  • Thread starter Mathick
  • Tags
    Polynomials
In summary, a pair of polynomials is a set of two algebraic expressions with matching variables and powers. They must have the same degree and identical terms, except for coefficients. They can have any number of terms and are solved by simplifying and setting them equal to each other. Finding pairs of polynomials is important in solving systems of equations and modeling real-world situations.
Mathick
23
Find all pairs of polynomials \(\displaystyle p(x)\) and \(\displaystyle q(x)\) with real coefficients for which both equations are satisfied: \(\displaystyle p(x^2+1)=q(x)^2+2x\) and \(\displaystyle q(x^2+1)=p(x)^2\). These equations are set for all real \(\displaystyle x\).
I tried to substitute \(\displaystyle x\) for \(\displaystyle -x\) and others numbers like \(\displaystyle -1,1\) etc. but nothing happened... I need your help
Not sure if this is going to lead anywhere or not.
In the first equation, substitute $x^2+1$ for $x$ to get $p\bigl((x^2+1)^2 + 1\bigr) = \bigl(q(x^2+1)\bigr)^2 + 2(x^2+1).$
Square both sides of the second equation to get $\bigl(q(x^2+1)\bigr)^2 = \bigl(p(x)\bigr)^4.$
Combine those two equations to get $p(x^4 + 2x^2+2) = \bigl(p(x)\bigr)^4 + 2x^2 + 2$.
Now what? Suppose that there is a solution in which $p(x)$ is a linear polynomial, say $p(x) = ax+b.$ Then $$a(x^4 + 2x^2+2) + b = (ax+b)^4 + 2x^2 + 2.$$ Compare coefficients of $x^4$ on both sides to see that $a=1$. Then compare coefficients of $x^3$ to get $b=0.$ That leads to a solution $\boxed{p(x) = x,\ q(x) = x-1}$.
Are there any other solutions? I don't know.
FAQ: What Polynomial Pairs Satisfy These Complex Functional Equations?
What is the definition of a pair of polynomials?
A pair of polynomials is a set of two polynomials, which are algebraic expressions that involve variables and coefficients. Each polynomial consists of one or more terms, where a term is made up of a coefficient and a variable raised to a power.
How do you determine if two polynomials are a pair?
In order for two polynomials to be considered a pair, they must have the same degree and identical terms, with the exception of the coefficients. This means that the variables and their respective powers must match in both polynomials.
Can a pair of polynomials have more than two terms?
Yes, a pair of polynomials can have more than two terms. As long as the terms are in the same order and have matching variables and powers, the polynomials can have any number of terms.
How do you solve a pair of polynomials?
To solve a pair of polynomials, you must first simplify each polynomial by combining like terms. Then, set the two polynomials equal to each other and solve for the variable. The resulting value of the variable will be the solution to the pair of polynomials.
What is the importance of finding pairs of polynomials in mathematics?
Finding pairs of polynomials is important in mathematics because it allows us to solve systems of equations, which are multiple equations with multiple variables. Pairs of polynomials can also be used to model real-world situations and make predictions about them.
